I am aware this question had been asked and answered before here and here, but I tried their suggested solutions with no luck.
The problem is as stated - wifi network list does not show up in the GUI, it doesn't even have the option turn wifi on/off. It used to be that sometimes it would show and sometimes it wouldn't, and in some cases it would randomly disconnect from the wifi network and wouldn't show them again.
In trying to fix that I found somewhere (i can't seem to find it again) stating I should use the files in here to fix the problem. I copied the files onto /lib/firmware/ath10k/QCA6174, replacing the files in there. I stupidly didn't save a copy of the other files, and ever since I replaced them the wifi doesn't show up at all.
So basically this is two related questions in one:
- Where do I find the original files for the
./QCA6174/hw2.1and./QCA6174/hw3.0folders? (is this even necessary) - How do I permanently solve this problem of wifi networks not showing or randomly disconnecting?
here is some possibly relevant info:
lshw:
~$ sudo lshw -C network *-network
description: Ethernet interface product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller vendor: Realtek Semiconductor Co., Ltd. physical id: 0 bus info: pci@0000:02:00.0 logical name: enp2s0 version: 08 serial: 50:7b:9d:cc:bc:da size: 10Mbit/s capacity: 100Mbit/s width: 64 bits clock: 33MHz capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8106e-2_0.0.1 04/23/13 latency=0 link=no multicast=yes port=MII speed=10Mbit/s resources: irq:45 ioport:3000(size=256) memory:c1004000-c1004fff memory:c1000000-c1003fff *-network description: Ethernet interface physical id: 3 logical name: bnep0 serial: 44:1c:a8:65:92:6c capabilities: ethernet physical configuration: broadcast=yes ip=192.168.44.206 multicast=yes
lspci:
~$ lspci -v ... 02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller (rev 08) Subsystem: Lenovo RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller Flags: bus master, fast devsel, latency 0, IRQ 45 I/O ports at 3000 [size=256] Memory at c1004000 (64-bit, non-prefetchable) [size=4K] Memory at c1000000 (64-bit, non-prefetchable) [size=16K] Capabilities: <access denied> Kernel driver in use: r8169 Kernel modules: r8169
rfkill:
~$ sudo rfkill list 0: ideapad_wlan: Wireless LAN Soft blocked: no Hard blocked: no 1: ideapad_bluetooth: Bluetooth Soft blocked: no Hard blocked: no 2: hci0: Bluetooth Soft blocked: no Hard blocked: no
iconfig:
~$ sudo iwconfig enp2s0 no wireless extensions. lo no wireless extensions. bnep0 no wireless extensions.
