Lenovo Thinkpad X240, Ubuntu 18.04. After suspend/hibernate the touchpad is not working. Keyboard or external mouse works. I'm new to Ubuntu
log:
11:03:24 wpa_supplicant: dbus: Failed to construct signal
11:03:23 kernel: rmi4_physical rmi4-00: rmi_driver_set_irq_bits: Failed to     change enabled interrupts!
11:03:23 kernel: rmi4_f03 rmi4-00.fn03: rmi_f03_pt_write: Failed to write to F03 TX register (-6).
11:03:23 kernel: rmi4_f01 rmi4-00.fn01: Resume failed with code -6.
11:03:23 kernel: rmi4_physical rmi4-00: rmi_driver_reset_handler: Failed to read current IRQ mask.
11:03:23 kernel: rmi4_smbus 0-002c: failed to get SMBus version number!
11:00:59 spice-vdagent: Cannot access vdagent virtio channel /dev/virtio-ports/com.redhat.spice.0
11:00:58 pulseaudio: [pulseaudio] backend-ofono.c: Failed to register as a handsfree audio agent with ofono: org.freedesktop.DBus.Error.ServiceUnknown: The name org.ofono was not provided by any .service files
11:00:43 kernel: Cannot access vdagent virtio channel /dev/virtio-ports/com.redhat.spice.0
11:00:42 wpa_supplicant: dbus: Failed to construct signal
11:00:40 systemd-rfkill: Failed to open device rfkill0: No such device
11:00:40 kernel: ACPI Error: Method parse/execution failed \_PR.CPU0._PDC, AE_AML_OPERAND_TYPE (20170831/psparse-550)
How can I fix this problem?
Zanna
  • 72,312
I know this is an old issue, but it is still relevant today.
I have the same problem Lenovo Thinkpad X240, Ubuntu 20.04
My solution:-
sudo nano /lib/systemd/system-sleep/rmi-driver
Add the following:-
#!/bin/sh
case $1 in
  post)
    rmmod rmi_core
    rmmod rmi_smbus
    modprobe rmi_core
    modprobe rmi_smbus
esac
Set executable:-
sudo chmod +x /lib/systemd/system-sleep/rmi-driver
On wake-up the touchpad will be working :)
llcool
  • 31
