I am trying to a salvage an old scratched DVD by ripping it to ISO. I have two readers and created an ISO from each. Each reader is unable to read certain different bytes of the DVD and replaces them with 0s. When I compare the files using cmp -l file1.iso file2.iso, I see that certain bytes on the left are 0 while certain other bytes on the right are 0 (the corresponding bytes on the other files are non-zero). I want to create a 3rd file, say file3.iso that merges the non-zero differing bytes from the above two files. As an example, assume for simplicity that each file has 6 bytes as follows
file1.iso   file2.iso
0           0
1           1
2           0
3           0
0           4
0           5
file3.iso should be as follows:
The files are quite large (around 8GB). Each file has the same number of bytes. I am using Ubuntu 16.04
Can anyone suggest the easiest way to do what I want. I can use the output of cmp -l as intermediate data but want to avoid writing code.
Jus12
  • 183
I wrote a Python script for you.
#!/usr/bin/env python3
Given two input files and one output file, merge the input files on
matching bytes or bytes that are null in one file but not the other.
Non-matching non-null bytes will raise a ValueError.
import sys
args = sys.argv[1:]
file1 = open(args[0], 'rb')
file2 = open(args[1], 'rb')
file_out = open(args[2], 'wb')
def get_bytes(file):
    '''Return a generator that yields each byte in the given file.'''
    def get_byte():
        return file.read(1)
    return iter(get_byte, b'')
for i, (byte1, byte2) in enumerate(zip(get_bytes(file1), get_bytes(file2))):
    if byte1 == byte2:
        byte_out = byte1
    elif ord(byte1) == 0:
        byte_out = byte2
    elif ord(byte2) == 0:
        byte_out = byte1
    else:
        msg = 'Bytes at {:#x} are both non-zero and do not match: {}, {}'
        raise ValueError(msg.format(i, byte1, byte2))
    file_out.write(byte_out)
Make it executable then call it like so:
$ ./test.py file1.iso file2.iso file3.iso
Or for short:
$ ./test.py file{1,2,3}.iso
P.s. I've recently been studying reading files in different ways, so this is nice serendipity.
wjandrea
  • 14,504
