The first thing to say is that I have explored and tried the solutions suggested in other similar questions but so far nothing has worked. I know the USB Wifi is not faulty as it just works fine in Windows 10 on the same machine. Incidentally it also doesn't work in Mac OS 10.13.6 (This is a 2011 MacBook Pro with a broken internal WiFi adapter).
lsusb
gives the following: Bus 002 Device 006: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
dmesg
just after plugging the device in gives:
[ 2265.257271] usb 1-1.3: new high-speed USB device number 11 using ehci-pci
[ 2265.376911] usb 1-1.3: New USB device found, idVendor=148f, idProduct=7601
[ 2265.376915] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2265.376917] usb 1-1.3: Product: 802.11 n WLAN
[ 2265.376919] usb 1-1.3: Manufacturer: MediaTek
[ 2265.376921] usb 1-1.3: SerialNumber: 1.0
If I try iwconfig:
$ iwconfig
lo        no wireless extensions.
enp2s0f0  no wireless extensions.
I have downloaded the firmware from the Mediatek website and put it in the right folder and have also tried to compile or install various packages which either threw compilation errors or did nothing to get the WiFi working.
Does anyone have any advice or an up-to date solution for this?
I tried to follow the instructions given for @chili555's answer:
     $ make
    make -C tools
    make[1]: Entering directory '/home/baldwin/mt7601usta/src/tools'
    gcc -g bin2h.c -o bin2h
    make[1]: Leaving directory '/home/baldwin/mt7601usta/src/tools'
    /home/baldwin/mt7601usta/src/tools/bin2h
    cp -f os/linux/Makefile.6 /home/baldwin/mt7601usta/src/os/linux   /Makefile
    make -C /lib/modules/4.15.0-39-generic/build SUBDIRS=/home/baldwin  /mt7601usta/src/os/linux modules
    make[1]: Entering directory '/usr/src/linux-headers-4.15.0-39-generic'
     CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../os/linux /rt_profile.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../sta/assoc.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../sta/auth.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../sta/auth_rsp.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../sta/sync.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../sta/sanity.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../sta/rtmp_data.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../sta/connect.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../sta/wpa.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../sta/sta_cfg.o
     /home/baldwin/mt7601usta/src/os/linux/../../sta/sta_cfg.c: In           function ‘Set_EncrypType_Proc’:
    /home/baldwin/mt7601usta/src/os/linux/../../sta/sta_cfg.c:1104:5: warning:   this ‘else’ clause does not guard... [-Wmisleading-indentation]
        else
        /home/baldwin/mt7601usta/src/os/linux/../../sta/sta_cfg.c:1107:2:    note: ...this statement, but the latter is misleadingly indented as if it were    guarded by the ‘else’
      if (pAd->StaCfg.BssType == BSS_ADHOC)
    /home/baldwin/mt7601usta/src/os/linux/../../sta/sta_cfg.c: In function      ‘RtmpIoctl_rt_ioctl_siwfreq’:
    /home/baldwin/mt7601usta/src/os/linux/../../sta/sta_cfg.c:6018:5:     warning: this ‘else’ clause does not guard... [-Wmisleading-indentation]
         else
    /home/baldwin/mt7601usta/src/os/linux/../../sta/sta_cfg.c:6021:2:   note: ...this statement, but the latter is misleadingly indented as if it were  guarded by the ‘else’
      return NDIS_STATUS_SUCCESS;
    /home/baldwin/mt7601usta/src/os/linux/../../sta/sta_cfg.c: In function      ‘RtmpIoctl_rt_ioctl_giwrate’:
    /home/baldwin/mt7601usta/src/os/linux/../../sta/sta_cfg.c:7928:5:  warning: this ‘if’ clause does not guard... [-Wmisleading-indentation]
          if (rate_index >= rate_count)
    /home/baldwin/mt7601usta/src/os/linux/../../sta/sta_cfg.c:7931:2:  note: ...this statement, but the latter is misleadingly indented as if it were  guarded by the ‘if’
      *(ULONG *)pData = ralinkrate[rate_index] * 500000;
     CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common /crypt_md5.o
     CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/crypt_sha2.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/crypt_hmac.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/crypt_aes.o
       CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common   /crypt_arc4.o
       CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/mlme.o
       CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_wep.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/action.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_data.o
       CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/rtmp_init.o
    /home/baldwin/mt7601usta/src/os/linux/../../common/rtmp_init.c: In  function ‘NICInitializeAsic’:
    /home/baldwin/mt7601usta/src/os/linux/../../common/rtmp_init.c:1656:1:  warning: the frame size of 1048 bytes is larger than 1024 bytes [-Wframe- larger-than=]
       CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common /rtmp_init_inf.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_tkip.o
       CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_aes.o
       CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_sync.o
       CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/eeprom.o
       CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_sanity.o
       CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common /cmm_info.o
     /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_info.c: In    function ‘GetEncryptType’:
    /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_info.c:1752:5:      warning: this ‘if’ clause does not guard... [-Wmisleading-indentation]
         if(enc == Ndis802_11Encryption3Enabled)
    /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_info.c:1754:2: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’
       if(enc == Ndis802_11Encryption4Enabled)
    /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_info.c: In function ‘GetAuthMode’:
    /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_info.c:1764:5: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation]
         if(auth == Ndis802_11AuthModeShared)
    /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_info.c:1766:2:    note: ...this statement, but the latter is misleadingly indented as if it were   guarded by the ‘if’
      if(auth == Ndis802_11AuthModeAutoSwitch)
     /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_info.c:1776:5:   warning: this ‘if’ clause does not guard... [-Wmisleading-indentation]
         if(auth == Ndis802_11AuthModeWPA2PSK)
    /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_info.c:1778:2: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’
       if(auth == Ndis802_11AuthModeWPA1WPA2)
    /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_info.c: In  function ‘Show_PMK_Proc’:
    /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_info.c:4198:5:  warning: this ‘for’ clause does not guard... [-Wmisleading-indentation]
 for (idx = 0; idx < 32; idx++)
   /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_info.c:4201:2:  note: ...this statement, but the latter is misleadingly indented as if it were  guarded by the ‘for’
      return 0;
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_cfg.o
     CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_wpa.o
    /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_wpa.c: In    function ‘WPAStart2WayGroupHS’:
     /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_wpa.c:1257:5:      warning: this ‘if’ clause does not guard... [-Wmisleading-indentation]
        if ((!pEntry) || !IS_ENTRY_CLIENT(pEntry))
     /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_wpa.c:1262:2:    note: ...this statement, but the latter is misleadingly indented as if it were  guarded by the ‘if’
       os_alloc_mem(NULL, (PUCHAR *)&mpool, TX_EAPOL_BUFFER);
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_radar.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/spectrum.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/rtmp_timer.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/rt_channel.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_profile.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_asic.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/scan.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/cmm_cmd.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/uapsd.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/ps.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../rate_ctrl/ra_ctrl.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../rate_ctrl/alg_legacy.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../rate_ctrl/alg_ags.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../chips/rtmp_chip.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/txpower.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../mac/rtmp_mac.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../mgmt/mgmt_hw.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../..       /mgmt/mgmt_entrytb.o
   /home/baldwin/mt7601usta/src/os/linux/../../mgmt/mgmt_entrytb.c: In    function ‘MacTableInsertEntry’:
     /home/baldwin/mt7601usta/src/os/linux/../../mgmt/mgmt_entrytb.c:103:2: warning: this ‘if’ clause does not guard...  [-Wmisleading-indentation]
      if (pAd->MacTab.Size >= MAX_LEN_OF_MAC_TABLE)
    /home/baldwin/mt7601usta/src/os/linux/../../mgmt/mgmt_entrytb.c:106:3:   note: ...this statement, but the latter is misleadingly indented as if it were   guarded by the ‘if’
      FirstWcid = 1;
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../phy/rtmp_phy.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../phy/rlt_phy.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../phy/rlt_rf.o
      CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/ba_action.o
       CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../mgmt/mgmt_ht.o
       CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../common/rt_os_util.o
       CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../os/linux/sta_ioctl.o
       CC [M]  /home/baldwin/mt7601usta/src/os/linux/../../os/linux  /rt_linux.o
    /home/baldwin/mt7601usta/src/os/linux/../../os/linux/rt_linux.c: In function ‘__RTMP_OS_Init_Timer’:
    /home/baldwin/mt7601usta/src/os/linux/../../os/linux/rt_linux.c:120:3: error: implicit declaration of function ‘init_timer’; did you mean  ‘init_timers’? [-Werror=implicit-function-declaration]
       init_timer(pTimer);
        init_timers
    /home/baldwin/mt7601usta/src/os/linux/../../os/linux/rt_linux.c:121:9: error: ‘OS_NDIS_MINIPORT_TIMER {aka struct timer_list}’ has no member named  ‘data’
        pTimer->data = (unsigned long)data;
     /home/baldwin/mt7601usta/src/os/linux/../../os/linux       /rt_linux.c:122:20: error: assignment from incompatible pointer type    [-Werror=incompatible-pointer-types]
      pTimer->function = function;
     cc1: some warnings being treated as errors
     scripts/Makefile.build:332: recipe for target '/home/baldwin/mt7601usta/src/os/linux/../../os/linux/rt_linux.o' failed
     make[2]: *** [/home/baldwin/mt7601usta/src/os/linux/../../os/linux/rt_linux.o] Error 1
      Makefile:1551: recipe for target '_module_/home/baldwin/mt7601usta /src/os/linux' failed
      make[1]: *** [_module_/home/baldwin/mt7601usta/src/os/linux] Error 2
       make[1]: Leaving directory '/usr/src/linux-headers-4.15.0-39-   generic'
     Makefile:418: recipe for target 'LINUX' failed
     make: *** [LINUX] Error 2
Then, just in case it had somehow worked anyway:
$ sudo modprobe mt7601Usta
    modprobe: FATAL: Module mt7601Usta not found in directory /lib/modules  /4.15.0-39-generic
Information from latest comment: $ sudo updatedb && locate mt7601u.ko
/lib/modules/4.15.0-38-generic/kernel/drivers/net/wireless/mediatek  /mt7601u/mt7601u.ko
/lib/modules/4.15.0-39-generic/kernel/drivers/net/wireless/mediatek/mt7601u/mt7601u.ko
    $ sudo modprobe mt7601u && dmesg | grep mt76
[ 1102.391048] mt7601u 1-1.3:1.0: ASIC revision: 76010001 MAC revision:     76010500
[ 1102.432663] mt7601u 1-1.3:1.0: EEPROM ver:0c fae:00
[ 1102.610548] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[ 1102.610690] mt7601u 1-1.3:1.0: Error: MCU resp urb failed:-71
[ 1102.610703] mt7601u 1-1.3:1.0: Error: MCU resp evt:0 seq:5-4!
[ 1102.614793] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[ 1102.615055] mt7601u 1-1.3:1.0: Error: MCU resp urb failed:-71
[ 1102.615063] mt7601u 1-1.3:1.0: Error: MCU resp evt:0 seq:5-4!
[ 1102.619034] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[ 1102.619356] mt7601u 1-1.3:1.0: Error: MCU resp urb failed:-71
[ 1102.619375] mt7601u 1-1.3:1.0: Error: MCU resp evt:0 seq:5-4!
[ 1102.623360] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[ 1102.623598] mt7601u 1-1.3:1.0: Error: MCU resp urb failed:-71
[ 1102.623619] mt7601u 1-1.3:1.0: Error: MCU resp evt:0 seq:5-4!
[ 1102.627523] mt7601u 1-1.3:1.0: Error: RX urb failed:-71
[ 1102.627782] mt7601u 1-1.3:1.0: Error: MCU resp urb failed:-71
[ 1102.627785] mt7601u 1-1.3:1.0: Error: MCU resp evt:0 seq:5-4!
[ 1102.627787] mt7601u 1-1.3:1.0: Error: mt7601u_mcu_wait_resp timed out
[ 1102.795071] mt7601u: probe of 1-1.3:1.0 failed with error -110
[ 1102.795178] usbcore: registered new interface driver mt7601u
Now I tried:
$ md5sum /lib/firmware/mt7610u.bin
696cedb8e76ecc0cda9f9b0d3972c64d  /lib/firmware/mt7610u.bin
Then:
$ sudo dpkg -s linux-firmware | grep Version
Version: 1.173.2
Having followed advice below and installing latest version of firmware:
$ dmesg | grep ath
This is still the same as before.
Your firmware file, mt7610u.bin, has a different md5sum and is presumably different that the latest included in linux-firmware. Let's install the later package and see if the mysterious errors disappear.
With a working internet connection by ethernet, tethering or whatever means possible, open a terminal and do:
cd /tmp
wget http://mirrors.kernel.org/ubuntu/pool/main/l/linux-firmware/linux-firmware_1.175.1_all.deb
sudo dpkg -i linux-firmware*.deb
Reboot and check:
dmesg | grep ath
chili555
  • 61,330
