Use Case
I have an Ubuntu server machine wrapped in a VM (vmdk file) that contains web application. I want to send this VM to someone and prevent him from accessing to the internal file system of the VM - I don't want to let him extract the machine's file system from the vmdk file.
The user can just start the machine or power it off (when the machine starts - it loads the application back-end services automatically).
Solutions?
I though about using a hard drive encryption (Full Disk Encryption using LUKS or other solutions like VeraCrypt) but my main concern is how it will be used in a server-based environment.
I don't want to let the user to enter any decryption keys or something like that - I saw that there are solutions for decrypting the file system automatically at start like here and here and it seems like i need to store the decryption keys inside the vm.
Is there a way to decrypt the machine by maybe using a remote user login? (I'm less concerned from more complex issues like side channel attacks or Hot VM Cloning). Or any other solution that can meet the use case?
Update
After @vidarlo answer I decided to go with the FDE solution understanding the trade-off.
Below the configuration instructions I used (Assume that the /boot resides on the /dev/sda1 unencrypted partition and the encrypted one is on the /dev/sdaX partition).
Create a new random password and store it in the luks key store:
sudo dd if=/dev/urandom of=/boot/keyfile bs=1024 count=4
sudo chmod 0400 /boot/keyfile
sudo cryptsetup luksAddKey /dev/sdaX /boot/keyfile
Get the UUID of the /dev/sda1 partition by running:
sudo ls -l /dev/disk/by-uuid/
Update the /etc/crypttab file with this content:
sdaX_crypt UUID=<UUID_OF_SDAX> /dev/disk/by-uuid/<UUID_OF_SDA1>:/keyfile luks,keyscript=/lib/cryptsetup/scripts/passdev
Update the initramfs
sudo update-initramfs -u
Reboot
sudo reboot
