I have a DELL laptop and I have upgraded Ubuntu on this machine without issue until now. I have tried several times to upgrade from 18.04 to 18.10 and I've tried some of the recommendations on this site to try and get it installed, but it always fails. I tried from Terminal and got more detail on the attempted upgrade when it failed which I have pasted below. Any ideas on what I'm doing wrong or could do to fix this? Thanks.
do-release-upgrade
Checking for a new Ubuntu release
Get:1 Upgrade tool signature [819 B]
Get:2 Upgrade tool [1,255 kB]
Fetched 1,256 kB in 0s (0 B/s)
authenticate 'cosmic.tar.gz' against 'cosmic.tar.gz.gpg'
extracting 'cosmic.tar.gz'
[sudo] password for steve:
Reading cache
Checking package manager
Reading package lists... Done
Building dependency tree
Hit ie.archive.ubuntu.com/ubuntu bionic InRelease
Ign dl.google.com/linux/chrome/deb stable InRelease
Hit ppa.launchpad.net/gencfsm/ppa/ubuntu bionic InRelease
Get:1 dl.google.com/linux/chrome/deb stable Release [943 B]
Get:2 dl.google.com/linux/chrome/deb stable Release.gpg [819 B]
Hit ppa.launchpad.net/klaus-vormweg/pan/ubuntu bionic InRelease
Hit ppa.launchpad.net/morphis/anbox-support/ubuntu bionic InRelease
Get:3 ppa.launchpad.net/ondrej/php/ubuntu bionic InRelease [20.8 kB]
Hit ppa.launchpad.net/ozmartian/apps/ubuntu bionic InRelease
Get:4 ppa.launchpad.net/ondrej/php/ubuntu bionic/main i386 Packages [43.6 kB]
Get:5 ppa.launchpad.net/ondrej/php/ubuntu bionic/main amd64 Packages [43.6 kB]
Fetched 109 kB in 0s (0 B/s)
(appstreamcli:15338): GLib-CRITICAL **: 14:05:45.946: g_variant_builder_end: assertion '!GVSB(builder)->uniform_item_types || GVSB(builder)->prev_item_type != NULL || g_variant_type_is_definite (GVSB(builder)->type)' failed
(appstreamcli:15338): GLib-CRITICAL **: 14:05:45.947: g_variant_new_variant: assertion 'value != NULL' failed
(appstreamcli:15338): GLib-ERROR **: 14:05:45.947: g_variant_new_parsed: 11-13:invalid GVariant format string
Trace/breakpoint trap (core dumped)
Updating repository information
Third party sources disabled
Some third party entries in your sources.list were disabled. You can
re-enable them after the upgrade with the 'software-properties' tool
or your package manager.
To continue please press [ENTER]
Hit http://ie.archive.ubuntu.com/ubuntu cosmic InRelease
Fetched 0 B in 0s (0 B/s)
(appstreamcli:15614): GLib-CRITICAL **: 14:06:55.537: g_variant_builder_end: assertion '!GVSB(builder)->uniform_item_types || GVSB(builder)->prev_item_type != NULL || g_variant_type_is_definite (GVSB(builder)->type)' failed
(appstreamcli:15614): GLib-CRITICAL **: 14:06:55.538: g_variant_new_variant: assertion 'value != NULL' failed
(appstreamcli:15614): GLib-ERROR **: 14:06:55.538: g_variant_new_parsed: 11-13:invalid GVariant format string
(appstreamcli:15829): GLib-CRITICAL **: 14:07:05.466: g_variant_builder_end: assertion '!GVSB(builder)->uniform_item_types || GVSB(builder)->prev_item_type != NULL || g_variant_type_is_definite (GVSB(builder)->type)' failed
(appstreamcli:15829): GLib-CRITICAL **: 14:07:05.466: g_variant_new_variant: assertion 'value != NULL' failed
(appstreamcli:15829): GLib-ERROR **: 14:07:05.466: g_variant_new_parsed: 11-13:invalid GVariant format string
(appstreamcli:16059): GLib-CRITICAL **: 14:07:13.383: g_variant_builder_end: assertion '!GVSB(builder)->uniform_item_types || GVSB(builder)->prev_item_type != NULL || g_variant_type_is_definite (GVSB(builder)->type)' failed
(appstreamcli:16059): GLib-CRITICAL **: 14:07:13.383: g_variant_new_variant: assertion 'value != NULL' failed
(appstreamcli:16059): GLib-ERROR **: 14:07:13.383: g_variant_new_parsed: 11-13:invalid GVariant format string
Error during update
A problem occurred during the update. This is usually some sort of
network problem, please check your network connection and retry.
E:Problem executing scripts APT::Update::Post-Invoke-Success 'if
/usr/bin/test -w /var/cache/app-info -a -e /usr/bin/appstreamcli;
then appstreamcli refresh-cache > /dev/null; fi', E:Sub-process
returned an error code
Restoring original system state
Aborting
Tried the update through the Distribution Upgrade popup which appeared onscreen. It also failed with the following message:
Error during update
A problem occurred during the update. This is usually some sort of network problem, please check your network connection and retry.
E:Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/cache/app-info -a -e /usr/bin/appstreamcli; then appstreamcli refresh-cache > /dev/null; fi', E:Sub-process returned an error code.
I'm just thinking - if a couple of people have mentioned my internet connection was running, which it was, or if I was using a proxy, which I'm not and the latest try at upgrade showed that there may be a connection issue, could the laptopwifi adapter be getting switched off as it tries to update?
karel
  • 122,292
  • 133
  • 301
  • 332
I had the same error (on an acer notebook) when trying
    sudo do-release-upgrade
What then worked without errors was
    sudo su -
    apt dist-upgrade
    do-release-upgrade
Franz
