Here what's happening when I try to log in.
I'm entering the right password
login screen
users at login screen
It brings me back me to the login screen.
I tried to change password via another user but it didn't help.
Zanna
  • 72,312
fica
  • 177
If you've been starting graphic applications from the terminal using sudo, that's what probably caused your problem. Always use sudo -H.
  • boot to the GRUB menu
  • choose Advanced Options
  • choose Recovery mode
  • choose Root access
  • at the # prompt, type:
    • sudo mount -o remount,rw / # remount the disk as rw
    • cd /home/your_username # change directory
    • ls -al .*thority* # list some files
You should see something like this...
-rw------- 1 your_username your_username 407910 Nov  2 08:56 .ICEauthority
-rw------- 1 your_username your_username     58 Jun 23  2017 .Xauthority
If it DOES NOT show -rw------- then...
  • sudo chmod 600 .*thority* # change file protection
If it DOES SHOW root root then...
  • sudo chown your_username:your_username .*thority* # change file ownership
  • reboot # reboot the computer
Reboot and see if you can log in.
heynnema
  • 73,649
