I'm trying to configure quota for my / mount on Ubuntu 11.10. I have added ,usrjquota=quota.user,grpjquota=quota.group,jqfmt=vfsv0 to it in fstab. Made mount -o remount / and quotacheck -avugm. But when I try to turn quota on quotaon -avug i get this messages:
quotaon: using //quota.group on /dev/xvda1 [/]: No such process
quotaon: Quota format not supported in kernel.
quotaon: using //quota.user on /dev/xvda1 [/]: No such process
As I understood googling, that Ubuntu kernel could be compiled without quota support.
Any ideas?
Thanks!
Chuguniy
  • 161
There's a bug filled into launchpad which describes and solves this problem.
In summary, the quota module (and others) was removed from the virtual kernel. If you are in a Virtual Machine or aws-EC2 this should be your problem.
The solution
On Oneiric and Precise install linux-image-extra-virtual package. On old versions the modules should be already patched into kernel (just update your system).
After that run modprobe quota_v2 and modprobe quota_v1 in order to get ready to run quotas. Also remember to put the modules on /etc/modules.
Run your quotaon command as usual.
