The following occurs when trying to configure Landscape Server 18.03 on a fresh install of Ubuntu Server 18.04:
[user]@[server]:~$ sudo apt install landscape-server-quickstart
Reading package lists... Done
Building dependency tree
landscape-server-quickstart : Depends: landscape-server (>= 18.03-
0ubuntu18.04.2) but it is not going to be installed
Depends: postgresql-10-debversion but it is
not installable or
postgresql-9.5-debversion but it is
not installable or
postgresql-9.3-debversion but it is
not installable
Edit: For clarification, when I run dpkg --get-selections | grep hold, there are no held packages. The system is completely up to date. Running it through aptitude doesn't fix anything, as the only solution it offers is to keep everything at the current version (so basically not installed).
