I've installed phpMyAdmin but I don't seem to be able to access it.
I have tried browsing to both localhost/phpMyAdmin and 94.249.188.109/phpMyAdmin and it still says "Not Found".
How do I access phpMyAdmin?
Flyk
  • 1,480
  • 18
  • 24
Then you haven't installed it correctly; try installing with this command:
sudo apt-get install libapache2-mod-auth-mysql php5-mysql phpmyadmin
If that doesn't work, then try this fix:
sudo ln -s /etc/phpmyadmin/apache.conf /etc/apache2/conf.d/phpmyadmin.conf
sudo /etc/init.d/apache2 reload
Elder Geek
  • 36,752
Install phpmyadmin using
sudo apt-get install libapache2-mod-auth-mysql phpmyadmin
Then go to http://localhost/phpmyadmin/. Just in case that does not work, go to http://127.0.0.1/phpmyadmin/.
