I connected a machine via ssh and ran a programme. It took too long to run the programme and I have to turn off my local machine. How can I run the programme background even close the ssh connection?
I am running the code but if I rerun the code, it took a lot of the time, if I close the ssh, the program will be closed, so there are there any method to make the running program still running background even I close the ssh connection.
GoingMyWay
  • 474
There are various options you have to achieve this.
  • append & to the command you run.
  • run nohup command & and then press enter
  • Use supervisor
I'd like to add a couple more tools to the list above
tmux is the more modern one and you can find numerous config examples on GitHub.
chin7an
