Ubuntu 18.10 Cosmic Cuttlefish is not connecting to my Android phone. It shows the error:
Unable to access "SDM636 MTP SN:E48333B7"
Couldn't find matching udev device.
What to do?
How to connect Android device using MTP Ubuntu- Youtube Tutorial
Connect an Android device using MTP in Ubuntu.
You need to follow following steps because ubuntu doesn't show your mtp devices (security reasons). Open a terminal and type commands
$ sudo apt-get install libmtp-common mtp-tools libmtp-dev libmtp-runtime libmtp9
$ sudo apt-get dist-upgrade
Remove # from in front of last line
$ sudo nano /etc/fuse.conf
connect your phone to your pc (unlocked)
$ lsusb
open new terminal and type the following command
$ sudo nano /lib/udev/rules.d/69-mtp.rules
copy and paste below lines and replace Device with your phone name and the addresses as shown in image below.
replace the addresses as in the image
# Device
ATTR{idVendor}=="XXXX", ATTR{idProduct}=="YYYY", SYMLINK+="libmtp-%k", ENV{ID_MTP_DEVICE}="1", ENV{ID_MEDIA_PLAYER}="1"
$ sudo nano /etc/udev/rules.d/51-android.rules
Replace the addresses as shown in the image
ATTR{idVendor}=="XXXX", ATTR{idProduct}=="YYYY", MODE=”0666"
$ sudo service udev restart
$ sudo reboot
