I am trying to install a program with the command:
~/Downloads$ sudo apt install  ./argos3_simulator-3.0.0-i686-beta52.deb
and I am getting the response (error) of:
Reading package lists... Done
Building dependency tree
Note, selecting 'argos3_simulator:i386' instead of './argos3_simulator-3.0.0-i686-beta52.deb'
The following packages have unmet dependencies.
 argos3_simulator:i386 : Depends: gcc:i386 (>= 4.2) but it is not installable
                         Depends: g++:i386 (>= 4.2) but it is not installable
                         Depends: cmake:i386 (>= 2.6) but it is not installable
                         Depends: freeglut3-dev:i386 (>= 2.6.0) but it is not installable
                         Depends: qt5-default:i386 (>= 5.5.1) but it is not installable
                         Depends: libxi-dev:i386 but it is not installable
                         Depends: libxmu-dev:i386 but it is not installable
                         Depends: libfreeimage-dev:i386 (>= 3.15) but it is not installable
                         Depends: libfreeimageplus-dev:i386 (>= 3.15) but it is not installable
                         Depends: liblua5.2-dev:i386 but it is not installable
                         Depends: lua5.2:i386 but it is not installable
I have used followed lots of forum advice such as; using synaptic and made sure gcc and g++ are installed and tried reinstalling them too.The rest I cannot find in synaptic. However I am still getting the error.
Any help is greatly appreciated, please note I am not an Ubuntu/Linux wizz! (this is probably obvious!)
First off to install a deb file I use
sudo dpkg -i  some-file.deb
so in your case issue
sudo dpkg -i    ./argos3_simulator-3.0.0-i686-beta52.deb
however looks like that deb wants the 32 bit libraries not the normal 64 bit ones so give yourself that
dpkg --print-foreign-architectures  # show what you currently have
sudo dpkg --add-architecture i386   # make your machine 32 bit savvy
Most importantly to jackup your machine so it becomes a developer box with a basic set of tools to compile code etc issue
sudo apt-get install  build-essential
now finally re-issue your original command
If its still showing similar errors just install them using (update with missing libraries in your error message) : [then re-issue original command again]
sudo apt-get install libfreeimageplus-dev:i386
UPDATE I battled using above approach, looks like the precompiled binary is using an obsolete library(s) so below will compile it from source (on 64 bit Ubuntu 16.04)
https://github.com/ilpincy/argos3
sudo apt-get install cmake libfreeimage-dev libfreeimageplus-dev  qt5-default freeglut3-dev libxi-dev libxmu-dev liblua5.2-dev lua5.2 doxygen graphviz graphviz-dev asciidoc
download the source code, compile and install by issuing following :
git clone git@github.com:ilpincy/argos3.git
cd argos3
mkdir build_simulator
cd build_simulator
cmake ../src
make
make doc
sudo make install
sudo ldconfig
I can confirm above runs OK ... ignore
[WARNING] Error opening directory "/home/scott/src/github.com/ilpincy/argos3/build_simulator/plugins/simulator/physics_engines/physx/": No such file or directory
then just issue this to see help
argos3 --help
From the log you post, it is installing argos3_simulator:i386 in one of your repo (package source), not the deb file you want to install. Install gdebiand use:
$ sudo apt install gdebi
$ sudo gdebi ./argos3_simulator-3.0.0-i686-beta52.deb
Wish gdebi can help you complete the dependencies. But of coz, maybe your repos have problem as mentioned by Michael Haken.
alfred
  • 603
