I have GRUB v 2.8.9 (Ubuntu 18.10). I want to install Remix OS in dual boot. I created an entry for Remix OS with GRUB Customizer. But when I'm trying to boot, I don't have any GRUB menu appearing.
So, I tried to fix that by editing /etc/default/grub, but there's no line GRUB_HIDDEN_TIMEOUT. I do have GRUB_TIMEOUT_STYLE="hidden" and GRUB_TIMEOUT="0".
How can I show my GRUB on boot?
Zanna
  • 72,312
Below are my GRUB settings, which do what you want. Make a backup of your /etc/default/grub file and try mine to see if does what you want.
Don't forget to run sudo update-grub any time you edit the file...
I noticed my GRUB_TIMEOUT line doesn't have quotes and
  • 0 means do not time out so skips menu,
  • postive number means skip menu after the given number of secs and
  • -1 means don't skip.
Also try removing the quotes from GRUB_TIMEOUT_STYLE. Also try setting that to menu, not countdown or hidden.
Check out the documentation to see what each setting does.
I think these are the main settings you need.
GRUB_TIMEOUT_STYLE=menu
GRUB_TIMEOUT=-1
My current /etc/default/grub
GRUB_DEFAULT=saved
GRUB_SAVEDEFAULT=true
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
GRUB_THEME=/boot/grub/themes/Aurora-Penguinis-GRUB2/theme.txt
Zanna
  • 72,312
