System: Ubuntu 16.04.5 LTS - Unity Desktop fresh install Dell XPS 9650 Intel 7700 HQ + Nvidia 1050 GTX mobile
I'm trying to get Nvidia drivers (415) + Cuda + prime select to run on my work Notebook. But every time the Intel graphicscard is selected, all symlinks are destroyed:
ng@dw10048-ubuntu ~ ls -al /usr/bin/nvidia-*
lrwxrwxrwx 1 root root     52 Nov 18 08:22 /usr/bin/nvidia-bug-report.sh -> /etc/alternatives/x86_64-linux-gnu_nvidia_bug_report
lrwxrwxrwx 1 root root     58 Nov 18 08:22 /usr/bin/nvidia-cuda-mps-control -> /etc/alternatives/x86_64-linux-gnu_nvidia-cuda-mps-control
lrwxrwxrwx 1 root root     57 Nov 18 08:22 /usr/bin/nvidia-cuda-mps-server -> /etc/alternatives/x86_64-linux-gnu_nvidia-cuda-mps-server
lrwxrwxrwx 1 root root     51 Nov 18 08:22 /usr/bin/nvidia-debugdump -> /etc/alternatives/x86_64-linux-gnu_nvidia-debugdump
-rwxr-xr-x 1 root root    270 Jan 30  2018 /usr/bin/nvidia-detector
lrwxrwxrwx 1 root root     54 Nov 18 08:22 /usr/bin/nvidia-persistenced -> /etc/alternatives/x86_64-linux-gnu_nvidia_persistenced
-rwxr-xr-x 1 root root 224600 Nov 13 15:33 /usr/bin/nvidia-settings
lrwxrwxrwx 1 root root     45 Nov 18 08:22 /usr/bin/nvidia-smi -> /etc/alternatives/x86_64-linux-gnu_nvidia_smi
lrwxrwxrwx 1 root root     49 Nov 18 08:22 /usr/bin/nvidia-xconfig -> /etc/alternatives/x86_64-linux-gnu_nvidia_xconfig
 ng@dw10048-ubuntu ~ ls -al /etc/alternatives/x86_64-linux-gnu_nvidia*
lrwxrwxrwx 1 root root 59 Nov 18 08:22 /etc/alternatives/x86_64-linux-gnu_nvidia_app_profile -> /usr/share/nvidia-415/nvidia-application-profiles-415.13-rc
lrwxrwxrwx 1 root root 74 Nov 18 08:22 /etc/alternatives/x86_64-linux-gnu_nvidia_app_profile_keys -> /usr/share/nvidia-415/nvidia-application-profiles-415.13-key-documentation
lrwxrwxrwx 1 root root 44 Nov 18 08:22 /etc/alternatives/x86_64-linux-gnu_nvidia_bug_report -> /usr/lib/nvidia-415/bin/nvidia-bug-report.sh
lrwxrwxrwx 1 root root 47 Nov 18 08:22 /etc/alternatives/x86_64-linux-gnu_nvidia-cuda-mps-control -> /usr/lib/nvidia-415/bin/nvidia-cuda-mps-control
lrwxrwxrwx 1 root root 56 Nov 18 08:22 /etc/alternatives/x86_64-linux-gnu_nvidia-cuda-mps-control.1.gz -> /usr/share/man/man1/alt-nvidia-415-cuda-mps-control.1.gz
lrwxrwxrwx 1 root root 46 Nov 18 08:22 /etc/alternatives/x86_64-linux-gnu_nvidia-cuda-mps-server -> /usr/lib/nvidia-415/bin/nvidia-cuda-mps-server
lrwxrwxrwx 1 root root 40 Nov 18 08:22 /etc/alternatives/x86_64-linux-gnu_nvidia-debugdump -> /usr/lib/nvidia-415/bin/nvidia-debugdump
lrwxrwxrwx 1 root root 38 Nov 18 08:22 /etc/alternatives/x86_64-linux-gnu_nvidia_drv -> /usr/lib/nvidia-415/xorg/nvidia_drv.so
lrwxrwxrwx 1 root root 29 Nov 18 08:22 /etc/alternatives/x86_64-linux-gnu_nvidia_modconf -> /lib/nvidia-415/modprobe.conf
lrwxrwxrwx 1 root root 43 Nov 18 08:22 /etc/alternatives/x86_64-linux-gnu_nvidia_persistenced -> /usr/lib/nvidia-415/bin/nvidia-persistenced
lrwxrwxrwx 1 root root 34 Nov 18 08:22 /etc/alternatives/x86_64-linux-gnu_nvidia_smi -> /usr/lib/nvidia-415/bin/nvidia-smi
lrwxrwxrwx 1 root root 43 Nov 18 08:22 /etc/alternatives/x86_64-linux-gnu_nvidia-smi.1.gz -> /usr/share/man/man1/alt-nvidia-415-smi.1.gz
lrwxrwxrwx 1 root root 38 Nov 18 08:22 /etc/alternatives/x86_64-linux-gnu_nvidia_xconfig -> /usr/lib/nvidia-415/bin/nvidia-xconfig
 ng@dw10048-ubuntu ~ sudo prime-select intel
Info: the current GL alternatives in use are: ['nvidia-415', 'nvidia-415']
Info: the current EGL alternatives in use are: ['nvidia-415', 'nvidia-415']
Info: selecting nvidia-415-prime for the intel profile
update-alternatives: /usr/lib/nvidia-415-prime/ld.so.conf wird verwendet, um /etc/ld.so.conf.d/x86_64-linux-gnu_GL.conf (x86_64-linux-gnu_gl_conf) im manuellen Modus bereitzustellen
update-alternatives: /usr/lib/nvidia-415-prime/ld.so.conf wird verwendet, um /etc/ld.so.conf.d/x86_64-linux-gnu_EGL.conf (x86_64-linux-gnu_egl_conf) im manuellen Modus bereitzustellen
update-alternatives: /usr/lib/nvidia-415-prime/alt_ld.so.conf wird verwendet, um /etc/ld.so.conf.d/i386-linux-gnu_GL.conf (i386-linux-gnu_gl_conf) im manuellen Modus bereitzustellen
update-alternatives: /usr/lib/nvidia-415-prime/alt_ld.so.conf wird verwendet, um /etc/ld.so.conf.d/i386-linux-gnu_EGL.conf (i386-linux-gnu_egl_conf) im manuellen Modus bereitzustellen
lrwxrwxrwx 1 root root 59 Nov 18 08:25 /etc/alternatives/x86_64-linux-gnu_nvidia_app_profile -> /usr/share/nvidia-415/nvidia-application-profiles-415.13-rc
lrwxrwxrwx 1 root root 74 Nov 18 08:25 /etc/alternatives/x86_64-linux-gnu_nvidia_app_profile_keys -> /usr/share/nvidia-415/nvidia-application-profiles-415.13-key-documentation
lrwxrwxrwx 1 root root 44 Nov 18 08:25 /etc/alternatives/x86_64-linux-gnu_nvidia_bug_report -> /usr/lib/nvidia-415/bin/nvidia-bug-report.sh
lrwxrwxrwx 1 root root 40 Nov 18 08:25 /etc/alternatives/x86_64-linux-gnu_nvidia-debugdump -> /usr/lib/nvidia-415/bin/nvidia-debugdump
lrwxrwxrwx 1 root root 29 Nov 18 08:25 /etc/alternatives/x86_64-linux-gnu_nvidia_modconf -> /lib/nvidia-415/modprobe.conf
lrwxrwxrwx 1 root root 34 Nov 18 08:25 /etc/alternatives/x86_64-linux-gnu_nvidia_smi -> /usr/lib/nvidia-415/bin/nvidia-smi
lrwxrwxrwx 1 root root 43 Nov 18 08:25 /etc/alternatives/x86_64-linux-gnu_nvidia-smi.1.gz -> /usr/share/man/man1/alt-nvidia-415-smi.1.gz
lrwxrwxrwx 1 root root 38 Nov 18 08:25 /etc/alternatives/x86_64-linux-gnu_nvidia_xconfig -> /usr/lib/nvidia-415/bin/nvidia-xconfig
I've read:
Ubuntu 18.04 boot stuck at message “Started NVIDIA Persistence Daemon” after installing nVidia 390.74
Ubuntu 17.10 boot stuck at message "Started NVIDIA Persistence Daemon" after installing nVidia 384.90
How to get nvidia-persistenced daemon to work properly?
https://bugs.launchpad.net/ubuntu/+source/nvidia-persistenced/+bug/1693123
But there only seems to be to two valid solutions:
  • Don't use Unity + GDM -> which I can't do, since we still deliver Software for 16.04 LTS, which needs to be tested in Unity
  • Use Nouveau or Intel drivers -> which isn't what i want to do since I want to use CUDA
So unless anyone knows something better I would create an alias which calls a wrapper script recreating all symlinks after switching.
Also does anybody know what the root cause of this problem is. Why are the symlinks delted?
Nils
  • 131
