60
I know I can check the currently installed non-free software with the following command (assuming aptitude is FOSS):
aptitude search '?installed (?section(restricted) | ?section(multiverse))'
And I can remove the "restricted" and "multiverse" sources (and not add any PPA's) to keep that list empty. I'm assuming from this point, whenever I apt install something, that something is either in the allowed sources or it is not found.
Is this enough? Does this make sure all software I'm running (in Ubuntu) is open-source?
Fabby
  • 35,017
vrms (Virtual Richard M. Stallman) to the rescue:
sudo apt install vrms
vrms
and you'll get something like:
      Non-free packages installed on computer-name
app-shortname1                    Application long name 1
app-shortname2                    Application long name 2
app-shortname3                    Application long name 3
       Contrib packages installed on computer-name
app-contrib1                      Application Contrib Name 1
  3 non-free packages, 0.4% of 2381 installed packages.
  1 contrib packages, 0.1% of 2381 installed packages.
that will ensure you do / do not have any proprietary software installed.
Note: CPU firmware patches are non-free but absolutely needed to protect you from some processor flaws and their ilks, so don't go overboard! ;-)
Fabby
  • 35,017
50
If you're keen on having only Free Software (although you used the term Open Source) on your computer, you may want to consider installing Ubuntu with the "Free Software Only" option. You can find out more over at this question.
Free software only option
popey
  • 24,549
