I have a brand new Ubuntu 18.10 VM (hosted on Windows 10), built from an osboxes.org image. Aside from totally unrelated minor stuff, all I've done on this virgin OS is:
sudo apt install git
sudo apt install ant
sudo apt install netbeans
but then when I tried to run netbeans, the command was not found. I had been away from my desk after the install, so I ran sudo apt install netbeans a second time. After that, netbeans command is found, and a NetBeansIDE splash window shows for a while, but then it goes away.
Now I look at ~/.netbeans/var/log/messages.log and see a java.lang.NoClassDefFoundError.
In detail, it appears that java was already installed in the VM image from osboxes. java -version reports version 11.0.1 2018-10-16.
Having seen other posts, I did a sudo apt-get remove netbeans as well as sudo apt-get purge netbeans and then sudo apt-get install netbeans. This didn't help.
In further detail, it appears that the version of NetBeans being installed is 8.1. The content of messages.log is below:
Log Session: Friday, November 16, 2018 10:31:23 AM EST
System Info:
Product Version = NetBeans IDE 8.1 (Build 20180424-debian-8.1)
Operating System = Linux version 4.18.0-11-generic running on amd64
Java; VM; Vendor = 1.8.0_181; OpenJDK 64-Bit Server VM 25.181-b13; Oracle Corporation
Runtime = OpenJDK Runtime Environment 1.8.0_181-8u181-b13-1ubuntu0.18.10.1-b13
Java Home = /usr/lib/jvm/java-8-openjdk-amd64/jre
System Locale; Encoding = en_US (nb); UTF-8
Home Directory = /home/helmut
Current Directory = /home/helmut
User Directory = /home/helmut/.netbeans/8.1
Cache Directory = /home/helmut/.cache/netbeans/8.1
Installation = /usr/share/netbeans/8.1/nb
/usr/share/netbeans/8.1/ide
/usr/share/netbeans/8.1/java
/usr/share/netbeans/8.1/apisupport
/usr/share/netbeans/8.1/harness
/usr/share/netbeans/8.1/platform
Boot & Ext. Classpath = /usr/lib/jvm/java-8-openjdk-amd64/jre/lib/resources.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/rt.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/sunrsasign.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/jsse.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/jce.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/charsets.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/jfr.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/classes:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/ext/localedata.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/ext/jaccess.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/ext/dnsns.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/ext/sunec.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/ext/java-atk-wrapper.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/ext/nashorn.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/ext/icedtea-sound.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/ext/cldrdata.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/ext/zipfs.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/ext/sunjce_provider.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/ext/sunpkcs11.jar
Application Classpath = /usr/share/java/jcodings.jar:/usr/share/netbeans/8.1/platform/lib/boot.jar:/usr/share/netbeans/8.1/platform/lib/org-openide-modules.jar:/usr/share/netbeans/8.1/platform/lib/org-openide-util.jar:/usr/share/netbeans/8.1/platform/lib/org-openide-util-lookup.jar:/usr/share/netbeans/8.1/platform/lib/org-openide-util-ui.jar:/usr/lib/jvm/java-8-openjdk-amd64/lib/dt.jar:/usr/lib/jvm/java-8-openjdk-amd64/lib/tools.jar
Startup Classpath = /usr/share/netbeans/8.1/platform/core/org-openide-filesystems-compat8.jar:/usr/share/netbeans/8.1/platform/core/core-base.jar:/usr/share/netbeans/8.1/platform/core/asm-all-5.0.1.jar:/usr/share/netbeans/8.1/platform/core/core.jar:/usr/share/netbeans/8.1/platform/core/org-openide-filesystems.jar:/usr/share/netbeans/8.1/platform/core/org-netbeans-libs-asm.jar:/usr/share/netbeans/8.1/nb/core/org-netbeans-upgrader.jar:/usr/share/netbeans/8.1/nb/core/locale/core_nb.jar
java.lang.NoClassDefFoundError: org/eclipse/osgi/baseadaptor/HookConfigurator while loading org.netbeans.modules.netbinox.NetbinoxHooks; see http://wiki.netbeans.org/DevFaqTroubleshootClassNotFound
at org.netbeans.ProxyClassLoader.selfLoadClass(Unknown Source)
at org.netbeans.ProxyClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.netbeans.modules.netbinox.NetbinoxFactory.newFramework(Unknown Source)
at org.netbeans.core.netigso.Netigso.prepare(Unknown Source)
at org.netbeans.NetigsoHandle.turnOn(Unknown Source)
at org.netbeans.ModuleManager.enable(Unknown Source)
INFO [null]: Last record repeated again.
at org.netbeans.core.startup.ModuleList.installNew(Unknown Source)
at org.netbeans.core.startup.ModuleList.trigger(Unknown Source)
at org.netbeans.core.startup.ModuleSystem.restore(Unknown Source)
at org.netbeans.core.startup.Main.getModuleSystem(Unknown Source)
at org.netbeans.core.startup.Main.start(Unknown Source)
at org.netbeans.core.startup.TopThreadGroup.run(Unknown Source)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/osgi/baseadaptor/HookConfigurator
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:763)
at org.netbeans.JarClassLoader.doLoadClass(Unknown Source)
... 16 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.osgi.baseadaptor.HookConfigurator starting from ModuleCL@459c3d83[org.netbeans.modules.netbinox] with possible defining loaders [ModuleCL@459c3d83[org.netbeans.modules.netbinox]] and declared parents [org.netbeans.MainImpl$BootClassLoader@41629346, ModuleCL@7636aab3[org.netbeans.core.netigso], ModuleCL@629a3076[org.netbeans.libs.osgi]]
... 19 more
