  • I have installed Ubuntu 18.04 in my Lenovo laptop.
  • It does not show up the WiFi options.
  • I tried downloading the drivers and installing them in the way as described here Wi-Fi not working on Lenovo ThinkPad E570 (Realtek RTL8821CE). But nothing in use.
  • Whenever i try to use make command, I get
    /bin/sh: 1: cc: not found
    (standard_in) 1: syntax error
    make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/4.15.0-39-generic/build M=/home/bee/Downloads/rtl8821ce  modules
    make[1]: Entering directory '/usr/src/linux-headers-4.15.0-39-generic'
    arch/x86/Makefile:156: CONFIG_X86_X32 enabled but no binutils support
    ./scripts/gcc-version.sh: line 26: gcc: command not found
    ./scripts/gcc-version.sh: line 27: gcc: command not found
    make[1]: gcc: Command not found
    Makefile:975: "Cannot use CONFIG_STACK_VALIDATION=y, please install libelf-dev, libelf-devel or elfutils-libelf-devel"
    /bin/sh: 1: gcc: not found
     CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_cmd.o
    scripts/Makefile.build:332: recipe for target
    '/home/bee/Downloads/rtl8821ce/core/rtw_cmd.o' failed
     make[2]: *** [/home/bee/Downloads/rtl8821ce/core/rtw_cmd.o] Error 127
     Makefile:1551: recipe for target '_module_/home/bee/Downloads/rtl8821ce' failed
     make[1]: *** [_module_/home/bee/Downloads/rtl8821ce] Error 2
     make[1]: Leaving directory '/usr/src/linux-headers-4.15.0-39-generic'
     Makefile:1902: recipe for target 'modules' failed
     make: *** [modules] Error 2
EDIT 1
  • After installing build-essential also the problem exists with the error.
    cc1: error: code model kernel does not support PIC mode
EDIT 2 - I have upgraded my kernel to 4.18.6 and also installed libelf-dev. Again when I enter make command. It gives
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/4.18.6-041806-generic/build M=/home/bee/Downloads/rtl8821ce  modules
make[1]: Entering directory '/usr/src/linux-headers-4.18.6-041806-generic'
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_security.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_debug.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_io.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_ioctl_query.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_ioctl_set.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_ieee80211.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_mlme.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_mlme_ext.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_mi.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_wlan_util.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_vht.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_pwrctrl.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_rf.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_recv.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_sta_mgt.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_ap.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_xmit.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_p2p.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_tdls.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_br_ext.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_iol.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_sreset.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_btcoex_wifionly.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_btcoex.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_beamforming.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/rtw_odm.o
  CC [M]  /home/bee/Downloads/rtl8821ce/core/efuse/rtw_efuse.o
  CC [M]  /home/bee/Downloads/rtl8821ce/os_dep/osdep_service.o
  CC [M]  /home/bee/Downloads/rtl8821ce/os_dep/linux/os_intfs.o
/home/bee/Downloads/rtl8821ce/os_dep/linux/os_intfs.c:1325:22: error: initialization from incompatible pointer type [-Werror=incompatible-pointer-types]
  .ndo_select_queue = rtw_select_queue,
/home/bee/Downloads/rtl8821ce/os_dep/linux/os_intfs.c:1325:22: note: (near initialization for ‘rtw_netdev_ops.ndo_select_queue’)
cc1: some warnings being treated as errors
scripts/Makefile.build:317: recipe for target '/home/bee/Downloads/rtl8821ce/os_dep/linux/os_intfs.o' failed
make[2]: *** [/home/bee/Downloads/rtl8821ce/os_dep/linux/os_intfs.o] Error 1
Makefile:1504: recipe for target '_module_/home/bee/Downloads/rtl8821ce' failed
make[1]: Leaving directory '/usr/src/linux-headers-4.18.6-041806-generic'
Sravan
You need to get the build-essentials package. Use the command
sudo apt install -y build-essential
Melebius
  • 11,750
abaddon s
  • 164
