I have the multi-functional printer/scanner Brother MFC-L2710DN.
But I cannot install its drivers on my computer with Ubuntu 18.04.
The USB-cable is connected.
I could not find drivers for MFC-L2710 in the table from Brother for Ubuntu.
What driver could I take for this device?
zx485
  • 2,865
BS_EW27
Thank you very much for your quick answers.
I solved the problem by installing
sudo ./linux-brprinter-installer-2.2.1-1
I went through all possible tutorials several times, but nothing helped but the installation of this Brother support entity.
This solved the problem.
I suspect a possible USB port corruption or lack of support for USB 3.0, because the scanner came to life when I passed it to another USB 2.0 port on my HPG255 laptop.
I will add that Ubuntu was upgraded from an older version on which drivers were already installed with a working scanner (on this port) and a working printer.
zx485
  • 2,865
This page helped me alot to get printer and scanner to work via network: https://wiki.ubuntuusers.de/Scanner/Brother/
Via USB the scaner ocasionally did not work for me.
The printer works fine via cups alone, but for the scanner the drivers "bscan4" and "bscan-skey" from the brother homepage are required.
Alex
  • 395
