Neither live CD nor USB image does boot in UEFI on my system. Black screen, that is all, no grub-efi does show up. So, not even coming close to the point to install or reinstall. With 18.04 UEFI ist fine and works as designed.
Asked
Active
Viewed 4,182 times
Boot from a live USB, (or the disk you used to install Ubuntu) the boot device selection in your bios may have multiple options. choose the UEFI device
Identify your boot device with sudo fdisk -l or gpartid.
chroot into your system. (/dev/sda in this example) replace sda# with your device
sudo mount /dev/sda2 /mnt #sda2 is the root partition
sudo mount /dev/sda1 /mnt/boot/efi #sda1 is the efi partition
for i in /dev /dev/pts /proc /sys; do sudo mount -B $i /mnt$i; done
sudo cp /etc/resolv.conf /mnt/etc/ #makes the network available after chrooting
modprobe efivars # make sure this is loaded
sudo chroot /mnt
Reinstall and update GRUB
apt-get install --reinstall grub-efi-amd64
or if you have a 32bit system:
then
update-grub
exit chroot with Ctrl+D
unmount everything and reboot
for i in /sys /proc /dev/pts /dev; do sudo umount /mnt$i; done
sudo umount /mnt/boot/efi #please do this. Corrupted efi partitions are not nice
sudo umount /mnt
sudo reboot
I've referenced these answers:
https://superuser.com/a/376471/953420
https://askubuntu.com/a/681442/234305
Starbuck
- 1,053
