While entering MySQL server I am getting an error like this:
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (111)
What's the problem and how can I fix it?
If your file my.cnf (usually in the /etc/mysql/ folder) is correctly configured with
socket=/var/lib/mysql/mysql.sockyou can check if mysql is running with the following command:
mysqladmin -u root -p statustry changing your permission to mysql folder. If you are working locally, you can try:
sudo chmod -R 755 /var/lib/mysql/
