It's not possible to install anything on my Ubuntu 18.04 LTS. When I run
sudo apt-get upgrade
I get:
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
 wine32:i386 : Depends: libwine:i386 (= 3.0-1ubuntu1) but it is not installed
 wine64 : Depends: libwine (= 3.0-1ubuntu1) but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
When I run
sudo  apt --fix-broken install
I get the error-messages after a while:
Correcting dependencies... Done
The following additional packages will be installed:
  fonts-wine libwine libwine:i386
The following NEW packages will be installed:
0 upgraded, 3 newly installed, 0 to remove and 10 not upgraded.
15 not fully installed or removed.
Need to get 0 B/39,9 MB of archives.
After this operation, 375 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 373690 files and directories currently installed.)
Preparing to unpack .../libwine_3.0-1ubuntu1_amd64.deb ...
Unpacking libwine:amd64 (3.0-1ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/libwine_3.0-1ubuntu1_amd64.deb (--unpack):
 trying to overwrite '/usr/lib/x86_64-linux-gnu/wine/acledit.dll.so', which is also in package wine1.8-amd64 1:1.8.0-0ubuntu1~ubuntu15.10.1~ppa1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Preparing to unpack .../libwine_3.0-1ubuntu1_i386.deb ...
Unpacking libwine:i386 (3.0-1ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/libwine_3.0-1ubuntu1_i386.deb (--unpack):
 trying to overwrite '/usr/lib/i386-linux-gnu/wine/acledit.dll.so', which is also in package wine1.8-i386:i386 1:1.8.0-0ubuntu1~ubuntu15.10.1~ppa1
Preparing to unpack .../fonts-wine_3.0-1ubuntu1_all.deb ...
Unpacking fonts-wine (3.0-1ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/fonts-wine_3.0-1ubuntu1_all.deb (--unpack):
 trying to overwrite '/usr/share/wine/fonts/coue1255.fon', which is also in package wine1.8 1:1.8.0-0ubuntu1~ubuntu15.10.1~ppa1
So something about wine....
Do you have any suggestions?
NickTux
  • 17,865
  • 57
  • 66
This seems similar problem as this one. It refers to another package, but the output error is the same trying to overwrite file, which is also in…
The solution here is to (force) remove the package that causes the error, directly with dpkg . The problematic package is mentioned after the which is also in <package to be removed>
In your case wine1.8-amd64 , wine1.8-i386 and wine1.8
The following commands should do the trick:
sudo dpkg -P wine1.8
sudo dpkg -P wine1.8-amd64
sudo dpkg -P wine1.8-i386
Then run again
sudo apt-get install -f
and dpkg should now be able to configure the packages correctly.
If for some reason above commands won't work, then use the --force-all option. Dangerous option as it can break things, but it is there for a reason.
sudo dpkg -P --force-all wine1.8
sudo dpkg -P --force-all wine1.8-amd64
sudo dpkg -P --force-all wine1.8-i386
Also, if you still have any PPA about wine enabled, please disable it or completely remove it.
NickTux
  • 17,865
  • 57
  • 66
