I am prompted for a sudo password.
Since I am a user at a very basic level of knowledge, I am very shaky in getting to the terminal and/or using the commands. When I am told to take the step "enter sudo command", before which I am prompted for the "sudo password", what do I do?
I've never set a sudo password. I see from other questions that there is a facility called passwd; surely that has to be entered at the terminal... I'll try it.
muru
  • 207,228
TonyB
  • 19
The sudo password is your normal user password by default in Ubuntu.
vidarlo
  • 23,497
welcome to linux!
First, you have to add yourself as a sudo-er. You need to do this as root, so you will need the root password.
Log in as root and type the following command:
adduser yourusername sudo
The log back out and log in to the yourusername account like you normally would
You should now have sudo permissions. You can test this by running the following command:
sudo ls
or some other benign command. If it accepts your password and runs the command, you are a sudo-er. You could also go to the settings and look in the user information, or probably another six different ways.
Your sudo password is cached in that terminal session for a while. So the next time you type a sudo command, it won't prompt you for a password.
Be careful though, if you are working as sudo, you can do great damage if you don't know what you're doing. Linux assumes you know what you're doing, with sudo there are no guardrails, you have the same power as root.
muru
  • 207,228
su used to be an acronym for Super User, i.e. root but now it stands for Substitute User. Root is like the administrator on Windows. And this makes sudo an acronym of Super User DO or Substitute User DO. By default su or sudo refers to root account (unless specified) which is generally password protected. Root account is password protected in order to restrict apps/normal users to perform certain tasks which can effect the performance of system or cause security threats.
Now, the sudo password is the password you used at the time of installation. Also, whenever you enter password it is hidden, i.e. no character/bullets/stars will appear like in Windows.
Kulfy
  • 18,154
