I have been trying to remove all the package.
apt-get remove --purge mysql*
apt-get remove --purge mariadb
apt-get remove --purge mariadb*
apt-get --purge remove mariadb-server
apt-get --purge remove python-software-properties
But after apt-get remove --purge mysql*, they need me to run apt --fix-broken install first
Try to remove mariadb apt-get remove --purge mariadb* and get
`Failed to stop mysql.service: Unit mysql.service not loaded.`
/usr/bin/deb-systemd-helper: error: unable to read mariadb.service
Try to start mysql and get this
Failed to start mysql.service: Unit mysql.service not found.
What should i do to remove all of it?
dionajie
  • 169
Try this:
  1. Purge mariadb
    sudo apt purge mariadb-*
    Remove all databases ('Yes' answer)
  2. Purge mysql
    sudo apt purge mysql-*
  3. Remove mariadb repo from /etc/apt/sources.list
    Find something like this:
    deb [arch=amd64,arm64,ppc64el] http://mariadb.mirror.globo.tech/repo/10.4/ubuntu bionic main
  4. Remove folders:
    sudo rm -r /usr/share/mysql/
    sudo rm -r /etc/mysql/
    sudo rm -r /lib/systemd/system/mysql.service
  5. Now you can try to install oracle mysql:
    sudo apt install mysql-server
Zanna
  • 72,312
I had success dealing with a similar problem by following the some of the steps listed in this post.
  1. Detect all MariaDB and MySQL packages
    apt search mariadb | grep "\[install"
    and
    apt search mysql | grep "\[install"
Unfortunately, before I was able to do the next step, I had to remove the various mariadb.service files, so that dpkg was able to remove the mariadb-server-10.3 package properly. Otherwise, it seems to be assuming there's a running service, and when it's unable to stop it (because the symlink is broken), it errors out.
I found mariadb.service in /etc/systemd/system and /etc/systemd/system/multi-user.target.wants
  1. Force uninstall of all MariaDB and MySQL packages (server, client, libs) to clean the mess
    sudo dpkg --force depends --purge <package> <package> ...
For the "Step 4" of that post, I swapped the order of the commands to remove the unneeded packages first:
sudo apt autoremove
sudo apt-get --fix-broken install
And then I was able to reinstall per the normal
sudo apt install mariadb-server
Hope that helps.
Zanna
  • 72,312
You can completely uninstall mysql / mariadb as follow:
sudo apt-get purge mariadb-server mariadb-* mysql-*
The purge is identical to remove, except that packages are removed and purged (any configuration files are deleted too)
PYK
  • 321
