24
I have Java 8 and Ubuntu 18.04. I'm using NetBeans and when tried to make some program, it couldn't be done because JavaFX is missing.
I installed Java JDK with NetBeans from Oracle's site and thought everything is included but obviously I didn't check it well.
What should I do, what should I install? I'm not so good at this and don't know if problem is with Ubuntu or Java. :(
maria
  • 915
5 Answers5
27
In the Ubuntu 16.04 and later default repositories JavaFX is packaged as a separate package named openjfx. To install it in Ubuntu 18.04, open the terminal and type:
sudo apt install openjdk-8-jdk openjfx
The openjfx package can also be installed from the default repositories in all currently supported versions of Ubuntu.
Check that JDK 8 is selected as the default Java version in Netbeans -> Tools -> Options -> Java -> Nashorn tab -> click the Manage Platforms button -> click the Add Platform button -> click the radio button marked Java Standard Edition -> click the Next button -> browse to /usr/lib/jvm/java-8-openjdk-amd64 and select it as the default Java version.
Optionally you can install openjdk-11-jdk instead of or alongside openjdk-8-jdk. openjfx works with both openjdk-8-jdk and openjdk-11-jdk in Netbeans in Ubuntu 18.04. I am using Netbeans 8.2 10.0 in Ubuntu 18.04.
karel
  • 122,292
  • 133
  • 301
  • 332
I think the easiest way is to install sdkman. Once installed, check for all the available candidates:
$ sdk list java
which will show a wide variety of options. You may select one with the FX suffix. In my case I can see something like this:
 Azul ZuluFX   |     | 11.0.2       | zulufx  |            | 11.0.2-zulufx
               |     | 8.0.202      | zulufx  |            | 8.0.202-zulufx
 BellSoft      |     | 12.0.2       | librca  |            | 12.0.2-librca
               |     | 11.0.4       | librca  |            | 11.0.4-librca
So, you can install it using this command:
$ sdk install java 11.0.2-zulufx
Or,
$ sdk install java 8.0.202-zulufx # if you want java 8
And you are good to go! I hope this helps! :)
This issue can be fixed by adding the openjfx path and modules as arguments when running the javafx application, I already posted the solution on this link.
Good luck
Lotfi
I had the same problem. I installed openjdk, but it wasn't compatible with openjfx, since the only version available is openjfx 11.
So i searched for a while and stumbled across ZuluFX. I installed it with sdkman, which you can download from their website. After installing sdkman, just install zulufx.
Your $JAVA_HOME should be the path where sdk man is installed -> /home/valentin/.sdkman/candidates/java/current
Now you can switch you JDK to that path in Netbeans and it should just work fine!
Liberica JDK "full" contains JavaFX. There are 8, 11 and latest versions as .tar.gz ans as .deb packages:
https://bell-sw.com/java.html
It is also available in sdkman as mentioned above (with updates).
For regular apt updates there is an official apt repository:
https://www.bell-sw.com/pages/repositories/#apt
To install version 11 containing FX use
sudo apt install bellsoft-java11-full
https://bell-sw.com/pages/repositories/#packages-versioning
Dmitry
