I have a hp spectre with an intel® Core™ i7-8705G CPU and an AMD radeon RX Vega GL discrete graphics card. I can't for the life of me figure out how to switch to my discrete card. My system doesn't even register that another graphics provider exists.
$ xrandr --listproviders
Providers: number : 1
Provider 0: id: 0x48 cap: 0x9, Source Output, Sink Offload crtcs: 3 outputs: 6 associated providers: 0 name:modesetting
There was a post some time back about a similar problem here but sadly this solution no longer seems to work. AMD doesn't even list the drivers for this card on their website so I'm kind of at a loss here.
Looking up the device with lshw at least shows that the hardware is detected
-display UNCLAIMED
       description: Display controller
       product: Polaris 22 XL [Radeon RX Vega M GL]
       vendor: Advanced Micro Devices, Inc. [AMD/ATI]
       physical id: 0
       bus info: pci@0000:01:00.0
       version: c0
       width: 64 bits
       clock: 33MHz
       capabilities: bus_master cap_list
       configuration: latency=0
       resources: iomemory:2f0-2ef iomemory:2f0-2ef memory:2fe0000000-2fefffffff memory:2ff0000000-2ff01fffff ioport:e000(size=256) memory:de400000-de43ffff memory:de440000-de45ffff
  *-display
       description: VGA compatible controller
       product: HD Graphics 630
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 04
       width: 64 bits
       clock: 33MHz
       capabilities: vga_controller bus_master cap_list rom
       configuration: driver=i915 latency=0
       resources: iomemory:2f0-2ef iomemory:2f0-2ef irq:126 memory:2ffe000000-2ffeffffff memory:2f80000000-2f8fffffff ioport:f000(size=64) memory:c0000-dffff
You need vegam firmware, new kernel 4.18 and mesa-utils amdgpu driver for ubuntu 18.04.
Vegam firmware
git clone https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/
sudo cp linux-firmware/amdgpu/*.bin /lib/firmware/amdgpu/
sudo /usr/sbin/update-initramfs -u -k all
Kernel 4.18
See this application to install new kernel. https://github.com/teejee2008/ukuu
sudo apt-add-repository -y ppa:teejee2008/ppa
sudo apt-get update
sudo apt-get install ukuu
Run the ukuu application and install kernel 4.18.17 or most recent one.
Mesa-utils Driver
sudo add-apt-repository ppa:ubuntu-x-swat/updates
sudo apt-get update
sudo apt install mesa-utils
After reboot, to verify if the vega gl is switchable, run the following command.
env DRI_PRIME=1 glxinfo | grep "OpenGL renderer"
