I have a directory of pictures.
I need the MD5-hash of each file in that directory and the name of the file placed into a .txt document. This file is to be read at a later time to reference the MD5 and file name together.
Note:
I would like this to just pull all directory files with me specifying them.
I have tried playing with tar and find and I just cannot seem to find a good solution...
This is a directory example:
/Desktop/testing
The .txt output is:
RandomFilename1,da39a3ee5e6b4b0d3255bfef95601890afd80709
RandomFilename2,da39a3ee5e6b4b0d3255bfef95601890afd80709
RandomFilename3,da39a3ee5e6b4b0d3255bfef95601890afd80709
I've looked everywhere online with no luck.
This will be on a Linux terminal.
muru
  • 207,228
You can use the following bash command:
for file in testing/*; do md5sum $file; done > res.txt
Of course you have to adjust the destination directory of res.txt.
The result could look similar to this:
8b1500ea6fe42927891fd1831bb955ba  testing/Pic1.gif
73f3222889a14411a3b78675ed0bc269  testing/Pic2.gif
c5b18ef1ea1346f13f668a7ead4e4c92  testing/Pic3.gif
So the MD5 hash is followed by the filename and path.
dessert
  • 40,956
zx485
  • 2,865
For what you want to do, execute md5sum and use sed or awk to transform the output
md5sum *.png | sed 's/^\([0-9a-f]\+\) \+\(.\+\)/\2,\1/' >images.md5sums
md5sum *.png | awk '{print $2","$1}' >image.md5sums
However, the plain output of md5sum is hash filename and is equivalent to your format. Using that standard md5sum output format is often more convenient, since you can use it directly with md5sum -c to check the hash of the files (after a copy or network transfer). Some other utilities may also expect this particular format.
dessert
  • 40,956
xenoid
  • 5,759
-1
I have written a small script as per the parameters defined:
cd /home/username/Desktop/testing
for F in *
do
    echo "$F", $(md5sum "$F" | sed -e 's/'"$F"'//g')
done
Example output:
1.txt, c8ef7cca2ceb3f878921b1ff163dbf91
demo, e9470a3c74b32036fa148dfabce70929
File with spaces.txt, c691b3d2fc2678839a9c141b6ee1524e
line.cpp, e0732d2781c6b2b57d413f79f9c1fd28
test, 3734699610e8d322767cf65f90ed43ce
test.cpp, afbe5b90cf002e1eb6df4cf98dfe4c0e
Note: This script would show the output in terminal. To save it in file you can use > 1.txt while executing the file, for e.g.:
./test.sh > 1.txt
Kulfy
  • 18,154
