I am really struggling to find the solution to this problem. I would really appreciate It if you guys could put the script in nano.
Asked
Active
Viewed 1,192 times
If you meant to get the public IP address, you only need this command curl ipinfo.io/ip
But if you want to use a shell script, follow these steps:
- run this command in the terminal
nano script.sh put these lines in your script:
#!/bin/bash curl ipinfo.io/ippress Ctrl + x , then y to save the changes.
- run
chmod +x script.shto make your script executable
To run the script use:
./script.sh
singrium
- 7,320
