When I try to connect to a VPN PPTP connection from Network Manager it fails with this message:
vpn connection failed because the vpn service failed to start.
It worked without any problem till I installed KVPNC application. I think that this app is the reason.
Peachy
  • 7,235
  • 40
  • 47
ali
  • 71
As justingrif suggested did you try removing kvpnc and test?
Also try the below steps:
  • "Available to all user" uncheck this option.
  • Advanced settings -> Security and Compression -> check "Use Point-to-Point encryption(MPPE)" option.
devav2
  • 37,290
