My VPN started disconnecting when I used the same VPN settings on 2 separate devices (should support up to 3 devices though). I tried reinstalling VPN software on the 2nd device before removing all parts of it which might be the problem now.
Can installing over an existing installation cause problems?
It now works fine on the device I haven't changed anything on, but the other says I now have a VPN connection (little lock in the corner) but when I open the browser there is no internet connection.
As soon as I disconnect the VPN I get access again.
Can anyone suggest what to do, or should look at changing/deleting/reinstalling?
Any possible solution?
How do I delete/uninstall everything I might have installed for VPN that could be causing conflict, in order to reinstall without duplicate application conflict. (this might be the problem...how can I tell?)
