70
I'm attempting to run a setup.exe file in wine which operates fine until I reach this error:
err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
I've used winetricks to download the .NET framework (dotnet40) and DirectX (directx9), yet still run into this error. I'm using Ubuntu 17.10. Any ideas?
mtrojak2
  • 821
I faced the same issue on Ubuntu 18.10. I had to de-install & re-install package winbind
sudo apt-get remove winbind && sudo apt-get install winbind
and this error went out... (another one remains, but that's probably another issue :
GnuTLS error: A TLS fatal alert has been received
Rachid O
  • 125
Thierry
  • 961
The issue can also be caused by one of the dependencies of ntlm_auth failing to run.
In my case for example, libsamba-util.so couldn't load because I had updated libicu, and samba was still expecting the older ABI.
mirh
  • 374
