I have been having issues with installing zlib1g-dev (I need it for rbenv to work). Apt will not install it, saying that I don't have the required dependencies (it doesn't say exactly which zlib1g i need, but I have the "2ubuntu4" version. I manually downloaded the package from the Ubuntu repos, however when I open it with Ubuntu Software it still does not install.
Error logs:
foo@foo:/$ sudo apt-get install zlib1g-dev
[sudo] password for foo:
Reading package lists... Done
Building dependency tree
 zlib1g-dev : Depends: zlib1g (= 1:1.2.8.dfsg-2ubuntu4) but 1:1.2.8.dfsg-2ubuntu4.1 is to be installed
The same issue happened to me on Focal, a pretty bare install from the default:
# apt install zlib1g-dev
The following packages have unmet dependencies.
zlib1g-dev : Depends: zlib1g (= 1:1.2.11.dfsg-2ubuntu1) but 1:1.2.11.dfsg-2ubuntu1.2 is to be installed
To get zlib1g-dev to install it was necessary to downgrade zlib1g, which tbh is ridiculous for something in the main repo:
# apt install zlib1g=1:1.2.11.dfsg-2ubuntu1
A similar issue happened when trying to install openssh-server after first post-install boot.
cEz
  • 266
