Yesterday I had been trying to update intel drivers and rebooted. I don't remember or have the commands I had used but since the reboot I have been unable to install any software or attempt to fix my computer. I'm still relatively new to Ubuntu, and I do not know what I messed up, though I believe it has to do with python version issues.
$ sudo apt-get -f install
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
    libc-ares2 libjs-bootstrap libjs-excanvas libjs-jquery-flot
    libjs-jquery-ui libjs-jquery-ui-theme-smoothness libjs-leaflet
    libjs-requirejs libjs-requirejs-text libllvm6.0:i386
    libopenscenegraph-3.4-131 libqt5opengl5   linux-headers-4.15.0-34
    linux-headers-4.15.0-34-generic linux-image-4.15.0-33-generic
    linux-image-4.15.0-34-generic linux-modules-4.15.0-33-generic
    linux-modules-4.15.0-34-generic linux-modules-extra-4.15.0-33-genericlinux-modules-extra-4.15.0-34-generic node-sprintf-js nodejs
    nodejs-doc
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 47 not fully
installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up python3 (3.6.5-3ubuntu1) ...
running python rtupdate hooks for python3.6...
E: py3compile:183: cannot create directory /usr/share/hplip/ui5/__pycache__:
    FileNotFoundError(2, 'No such file or directory')
    [Errno 2]  No such file or directory: '/usr/share/hplip/ui5/aboutdialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/aboutdialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/aligndialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/aligndialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/cleandialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/cleandialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/colorcaldialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/colorcaldialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/devicesetupdialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/devicesetupdialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/deviceuricombobox.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/devmgr5.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/devmgr5_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/devmgr_ext.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabgrouptable.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabnametable.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabwindow.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabwindow_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/faxsetupdialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/faxsetupdialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/filetable.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/firmwaredialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/firmwaredialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/infodialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/infodialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/linefeedcaldialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/linefeedcaldialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/loadpapergroupbox.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/makecopiesdialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/makecopiesdialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/mimetypesdialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/mimetypesdialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/nodevicesdialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/nodevicesdialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindiagnose.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindiagnose_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/pluginlicensedialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/pluginlicensedialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/pqdiagdialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/pqdiagdialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/printdialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/printdialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/printernamecombobox.py'
    [Errno 2] No such file or directory:'/usr/share/hplip/ui5/printsettings_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettingsdialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettingsdialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettingstoolbox.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/printtestpagedialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/printtestpagedialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/queuesconf.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/readonlyradiobutton.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/sendfaxdialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/sendfaxdialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/settingsdialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/settingsdialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/setupdialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/setupdialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/setupdialog_base5.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/systemtray.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/systrayframe.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/systrayframe_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/ui_utils.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/upgradedialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/upgradedialog_base.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/wifisetupdialog.py'
    [Errno 2] No such file or directory: '/usr/share/hplip/ui5/wifisetupdialog_base.py'
error running python rtupdate hook hplip-data
dpkg: error processing package python3
    (--configure):  installed python3 package post-installation script
    subprocess returned error exit status 4
dpkg: dependency problems prevent configuration of
      update-notifier-common:
      update-notifier-common depends on python3:any; however:   Package
    python3 is not configured yet.
dpkg: error processing package update-notifier-common
(--configure):  dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of ubuntu-web-launchers:
    ubuntu-web-launchers depends on python3; however:   Package python3 is
    not configured yet.
dpkg: error processing package ubuntu-web-launchers
dpkg: dependency problems prevent configuration of python3-brlapi:
    python3-brlapi depends on python3 (<< 3.7); however:
        Package python3 is not configured yet.
    python3-brlapi depends on python3 (= 3.6~); however:   Package
    python3-brlapi depends on python3:any (= 3.2~); however:   Package
  python3  update-notifier-common ubuntu-web-launchers  python3-brlapi
  lutris  python3-commandnotfound language-selector-common  python3-update-manager
  python3-dev python3-wadllib  gnome-shell  apport-gtk  apturl  netplan.io
  command-not-found  ubuntu-release-upgrader-core  python3-apport
  gnome-terminal  ubuntu-session  xserver-xorg  python3-problem-report
  ubuntu-drivers-common python3-uno  software-properties-gtk
  apturl-common  nplan  update-notifier  gnome-software  python3-pip
  unattended-upgrades  apport  update-manager python3-software-properties
  gnome-menus  language-selector-gnome networkd-dispatcher  python3-distupgrade
  xorg software-properties-common  nautilus-extension-gnome-terminal
  ubuntu-release-upgrader-gtk  update-manager-core  ubuntu-software
  python3-apt  gnome-software-plugin-snap  gdm3  gnome-control-center
I fear I have crippled my system and may need to do a fresh install.
Here is /etc/sources.list
# deb cdrom:[Ubuntu 18.04 LTS _Bionic Beaver_ - Release amd64 (20180426)]/ bionic main restricted
# See help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution. deb us.archive.ubuntu.com/ubuntu/ bionic main restricted
# deb-src us.archive.ubuntu.com/ubuntu/ bionic main restricted
## Major bug fix updates produced after the final release of the
## distribution. deb us.archive.ubuntu.com/ubuntu/ bionic-updates main restricted
# deb-src us.archive.ubuntu.com/ubuntu/ bionic-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team. deb us.archive.ubuntu.com/ubuntu/ bionic universe
# deb-src us.archive.ubuntu.com/ubuntu/ bionic universe deb us.archive.ubuntu.com/ubuntu/ bionic-updates universe
# deb-src us.archive.ubuntu.com/ubuntu/ bionic-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team. deb us.archive.ubuntu.com/ubuntu/ bionic multiverse
# deb-src us.archive.ubuntu.com/ubuntu/ bionic multiverse deb us.archive.ubuntu.com/ubuntu/ bionic-updates multiverse
# deb-src us.archive.ubuntu.com/ubuntu/ bionic-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team. deb us.archive.ubuntu.com/ubuntu/ bionic-backports main restricted
universe multiverse
# deb-src /us.archive.ubuntu.com/ubuntu/ bionic-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb archive.canonical.com/ubuntu bionic partner
# deb-src archive.canonical.com/ubuntu bionic partner
deb security.ubuntu.com/ubuntu bionic-security main restricted
# deb-src security.ubuntu.com/ubuntu bionic-security main restricted deb security.ubuntu.com/ubuntu bionic-security
universe
# deb-src security.ubuntu.com/ubuntu bionic-security universe deb security.ubuntu.com/ubuntu bionic-security multiverse
# deb-src security.ubuntu.com/ubuntu bionic-security multiverse
The problem came up after updating drivers, it did not come up when installing hplip, and the problem did not go away after removing hplip.
Zanna
  • 72,312
Two problems here:
  1. Your /etc/apt/sources.list looks wrong. You should restore it with normal one:
    deb http://archive.ubuntu.com/ubuntu bionic main restricted
    deb http://archive.ubuntu.com/ubuntu bionic multiverse
    deb http://archive.ubuntu.com/ubuntu bionic universe
    deb http://archive.ubuntu.com/ubuntu bionic-updates universe
    deb http://archive.ubuntu.com/ubuntu bionic-updates main restricted
    deb http://archive.ubuntu.com/ubuntu bionic-updates multiverse
    deb http://archive.ubuntu.com/ubuntu bionic-security main restricted
    deb http://archive.ubuntu.com/ubuntu bionic-security universe
    deb http://archive.ubuntu.com/ubuntu bionic-security multiverse
  2. It seems that you have installed binary HPLIP version, then follow Uninstallation section in duplicate answer and this will fix your problems.
Next time check your printer model and required HPLIP version more carefully.
N0rbert
  • 103,263
