When i try to compile in Geany i get the following error:
/bin/sh: 1: gcc: not found
When I run
sudo apt install gcc
This is what is printed on the screen:
Reading package lists... Done
Building dependency tree
 gcc : Depends: gcc-7 (>= 7.3.0-12~) but it is not going to be installed
       Recommends: libc6-dev but it is not going to be installed or
                   libc-dev
I am using Ubuntu 18.04.1 LTS
Zanna
  • 72,312
Vijay's comment fixed my problem. Thank you Vijay.
The answer is here.
That particular error message may indicate that you have held packages, but it may also indicate a different problem.
You can get a list of actual held packages with:
dpkg --get-selections | grep hold
If there are none, or none look related, then it's probably something else. Check carefully the output of the command you were trying when you got the error message, as there may be other clues in the full output from that command, aside from the error message.
Another method of troubleshooting may be to use aptitude rather than apt-get to try to install your package:
sudo aptitude install gcc
Aptitude will give up less easily, and will attempt to find solutions which may involve modifying other packages. It may give you more explanation of the problem and options for fixing it.
Occasionally aptitude will be too eager to remove or downgrade large numbers of packages to satisfy your request, in which case retrying with -f changes its priorities and helps it come up with solutions that involve removing/downgrading fewer packages even if it means not all changes you requested can go ahead:
sudo aptitude -f install gcc
The last two options fixed my problem, i hope that it helps someone else too.
