I'm seeing info on how to upgrade from a specific version to another, and that is what I want to do (currently 3.3.6), but is there a simple command to do this? I'm a complete ubuntu/linux noob so I have no idea what I'm talking about, I just want to upgrade php because my current version maybe limiting the amount of input elements that I can post to the following page.
Eric Carvalho
  • 55,453
jreed121
  • 247
It looks as if the problem is still under discussion on your question in stackoverflow, so ...
IMO you have two options:
dot.deb
dot.deb has php packages and I have used them on Ubuntu before.
Add the dot.deb repository
sudo echo "deb http://php53.dotdeb.org stable all" >> /etc/apt/sources.list
Install php5
sudo apt-get update
sudo apt-get install php5-cli php5-common php5-suhosin
compile php
From the precise repository - This may be safer ;)
apt-get install ubuntu-dev-tools
pull-lp-source php5 precise
dpkg-source -x php5_5.3.10-*.dsc
apt-get build-dep php5
cd php5-5.3.10
debuild binary
This second method was pulled from How to update to PHP 5.3.10 in 10.04?
Panther
  • 104,528
