115
I want to install npm. I've updated everything but I can't fix the problem.
The message I get is:
Reading package lists... Done
Building dependency tree
 npm : Depends: node-gyp (>= 0.10.9) but it is not going to be installed
Could you help me?
Zanna
  • 72,312
MatiasEze
  • 1,251
I was able to install npm by doing following:
sudo apt-get install nodejs-dev node-gyp libssl1.0-dev
and
sudo apt-get install npm
griever
  • 2,699
