I have a Windows 10 laptop (Lenovo Z570) and I decided to give Ubuntu a try and install it alongside Windows. So I shrank my D: partition using Windows disk management utility, downloaded the Ubuntu ISO image and booted it from USB. During the setup I chose the Something else option (Note: Ubuntu didn't detect Windows and didn't offer me the option to install it alongside Windows so I chose the Something else option) and made 3 partitions for root, swap and home. When I proceeded with the installation process, an error appeared saying
The 'grub-efi-amd64-signed package failed to install into an target. without the GRUB boot loader, the installed system will not boot.
So I ran the setup again and this time I chose to overwrite the existing Ubuntu installation that wasn't completed and this time the setup succeeded. But when I restarted my laptop, I found out my laptop booted directly into Ubuntu instead of showing me the bootloader. Just when I turn on my laptop and before Ubuntu logo appears, I encounter this error (this error got fixed but GRUB still can't detect Windows 10)
System BootOrder not found. Initializing defaults.
Things I have tried:
  • Running sudo update-grub and restarting
  • Running boot-repair and restarting and repeating that again (Here's the pastebin for the first time: http://paste.ubuntu.com/p/mnb2t6NYmz/ and the second: http://paste.ubuntu.com/p/2j2H8JvzYh/
  • Changing the boot order to give Ubuntu the priority
  • Mounting the Windows partition, then running sudo os-prober then sudo update-grub
  • Opening GRUB manually by pressing Esc in BIOS, but i just see Ubuntu listed and Windows isn't there
One thing I noticed when changing the boot order is that there were two values called ubuntu not one. Maybe this has to do with the first failed setup I did and then when I did a second setup so maybe it got a little messed up? (This also got fixed and instead it's a single value)
Give this a shot:
On a terminal type sudo update-grub. You should see something like: "windows detected". Restart, and hopefully when Ubuntu boots, you will see a menu to choose in which OS you want to boot.
If this doesn't work check out boot-repair.
Hope it helped
abu_bua
  • 11,313
