When running vulkaninfo, I get the following error.
It's been weeks that I try to get it running correctly on Ubuntu (vs 15 minutes flawlessly on Mac), trying almost every solution I stumbled upon. Any help would be very much appreciated.
Vulkan Instance Version: 1.1.85
vulkan/1.1.85.0/examples/vulkaninfo.c:3357: failed with VK_ERROR_INITIALIZATION_FAILED
Steps followed:
Here are the steps I followed in order to get there.
  1. I checked recommended NVidia driver
    sudo ubuntu-drivers devices
  2. I installed NVidia-driver-390 as recommended
    sudo apt-get install nvidia-driver-390
  3. I rebooted and realized that nvidia-prime is not being used
    sudo apt-get install nvidia-prime
    Still no nvidia Prime tab in Nvidia X Server Settings, let's try without.
  4. Download the vulkan SDK and followed these steps
  5. Add to ~/.profile.
    export VULKAN_SDK=/home/mies/vulkan/1.1.85.0/x86_64
    export PATH=$VULKAN_SDK/bin:$PATH
    export LD_LIBRARY_PATH=$VULKAN_SDK/lib
    export VK_LAYER_PATH=$VULKAN_SDK/etc/explicit_layer.d
  6. Build the examples. None works, I get this error.
    vulkan/1.1.85.0/examples/cube.c:3155: demo_init_vk: Assertion `!err' failed.
    [1]    31349 abort (core dumped)  ./cube
  7. When running vulkaninfo I get the error
    VK_ERROR_INITIALIZATION_FAILED.
Am I missing something?
Context is:
Driver check:
lspci -k | grep -A 2 -i "VGA"
01:00.0 VGA compatible controller: NVIDIA Corporation GF106GL [Quadro 2000] (rev a1)
Subsystem: NVIDIA Corporation Quadro 2000D
Kernel driver in use: nvidia
Config:
/usr/share/vulkan/icd.d/nvidia_icd.json:
    "file_format_version" : "1.0.0",
    "ICD": {
        "library_path": "libGLX_nvidia.so.0",
        "api_version" : "1.0.65"
Run via
dpkg-query: no packages found matching lunarg-vulkan-sdk
VIA_ERROR:   Vulkan failed to find a compatible driver.
Run dpkg-query -l "nvidia*" (w/ quotes for zsh)
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                                        Version                    Architecture               Description
un  nvidia-304                                  <none>                     <none>                     (no description available)
un  nvidia-340                                  <none>                     <none>                     (no description available)
un  nvidia-384                                  <none>                     <none>                     (no description available)
un  nvidia-390                                  <none>                     <none>                     (no description available)
un  nvidia-common                               <none>                     <none>                     (no description available)
ii  nvidia-compute-utils-390                    390.77-0ubuntu0.18.04.1    amd64                      NVIDIA compute utilities
ii  nvidia-dkms-390                             390.77-0ubuntu0.18.04.1    amd64                      NVIDIA DKMS package
un  nvidia-dkms-kernel                          <none>                     <none>                     (no description available)
ii  nvidia-driver-390                           390.77-0ubuntu0.18.04.1    amd64                      NVIDIA driver metapackage
un  nvidia-driver-binary                        <none>                     <none>                     (no description available)
un  nvidia-kernel-common                        <none>                     <none>                     (no description available)
ii  nvidia-kernel-common-390                    390.77-0ubuntu0.18.04.1    amd64                      Shared files used with the kernel module
un  nvidia-kernel-source                        <none>                     <none>                     (no description available)
ii  nvidia-kernel-source-390                    390.77-0ubuntu0.18.04.1    amd64                      NVIDIA kernel source package
un  nvidia-legacy-340xx-vdpau-driver            <none>                     <none>                     (no description available)
un  nvidia-opencl-icd                           <none>                     <none>                     (no description available)
un  nvidia-persistenced                         <none>                     <none>                     (no description available)
ii  nvidia-prime                                0.8.8.1                    all                        Tools to enable NVIDIA's Prime
ii  nvidia-settings                             390.77-0ubuntu0.18.04.1    amd64                      Tool for configuring the NVIDIA graphics driver
un  nvidia-settings-binary                      <none>                     <none>                     (no description available)
un  nvidia-smi                                  <none>                     <none>                     (no description available)
un  nvidia-utils                                <none>                     <none>                     (no description available)
ii  nvidia-utils-390                            390.77-0ubuntu0.18.04.1    amd64                      NVIDIA driver support binaries
un  nvidia-vdpau-driver                         <none>                     <none>                     (no description available)
I'm running out of ideas.
My NVidia Quadro 2000D is supposed to be supported, right?
muru
  • 207,228
aquiseb
  • 161
