When I use the command sudo systemctl hibernate, the system seems to go to hibernation, but when restarted, it is a fresh start without any of the previous windows that were left open.
And when I tried sudo pm-hibernate it says sudo: pm-hibernate: command not found.
Here is my drive configuration if that helps:
/dev/sda = SSD with Windows 10 only (Windows C drive and the reserved partition).
/dev/sdb = HDD with NTFS and EXT4 partitions containing regular data only, no OS here currently.
/dev/sdc = SSD (GPT partition) with Ubuntu 18.04 (/ partition), swap area and a shared NTFS game drive.
GRUB is installed on /dev/sda.
EDIT: I created a new parition table on /dev/sdc using msdos instead of GPT. Then I reinstalled Ubuntu and installed GRUB on /dev/sdc. After these changes, sudo hibernate seems to be working.
ANOTHER EDIT: Because sudo hibernate seems to go to hibernation without locking the screen (i.e. anyone could turn on the PC and automatically be logged in), I added this line to /etc/sudoers (cln is my username):
cln ALL=NOPASSWD: /usr/sbin/hibernate
and made this executable script:
#!/bin/bash
xdg-screensaver lock
sudo hibernate
Now I am able to just double-click on this script, select Run, and directly go to hibernation while also locking the screen. Much more comfortable.
CluelessNoob
  • 2,383
This instruction worked for my Ubuntu 18.04 installation.
  1. sudo apt install hibernate It will install hibernate and other dependencies which are needed to hibernate
  2. grep swap /etc/fstab (find UUID)
  3. sudoedit /etc/default/grub At the line GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" add UUID of swap.
    The line looks like this
    GRUB_CMDLINE_LINUX_DEFAULT="quiet splash resume=UUID=<UUID of swap>"
    You can choose
    `quiet splash` will hide the boot screen output
    splash will display the boot screen output
  4. sudo update-grub
  5. Restart, and after restart sudo systemctl hibernate. If everything works ok add menu entry's.
  6. sudo gedit /etc/polkit-1/localauthority/50-local.d/com.ubuntu.enable-hibernate.pkla now paste this:
[Re-enable hibernate by default in upower] Identity=unix-user:* Action=org.freedesktop.upower.hibernate ResultActive=yes [Re-enable hibernate by default in logind] Identity=unix-user:* Action=org.freedesktop.login1.hibernate;org.freedesktop.login1.handle-hibernate-key;org.freedesktop.login1;org.freedesktop.login1.hibernate-multiple-sessions;org.freedesktop.login1.hibernate-ignore-inhibit ResultActive=yes
  1. Restart the computer
  2. Install https://extensions.gnome.org/extension/755/hibernate-status-button/
Ayush Shukla
  • 105
This thread didn't solve my problem. I had to add pci=nomsi just before resume=.
take a look at this: Ubuntu 16.04 doesn't hibernate
