When trying to run sudo apt install debsig-verify which is needed to install Slack I got this error message:
You might want to run 'apt --fix-broken install' to correct these.
libreadline-dev:i386 :
Depends: libreadline7:i386 (= 7.0-3) but 7.0-0ubuntu2 is to be
installed
Depends: libtinfo-dev:i386 but it is not going to be installed libreadline7 :
Breaks: libreadline7:i386 (!= 7.0-3) but 7.0-0ubuntu2 is to be installed \
libreadline7:i386 :
Breaks: libreadline7 (!= 7.0-0ubuntu2) but 7.0-3 is to be installed`
When I tried sudo apt --fix-broken install I got these results:
The following additional packages will be installed:
libreadline7:i386
The following packages will be upgraded:
libreadline7:i386
1 upgraded, 0 newly installed, 0 to remove and 25 not upgraded.
4 not fully installed or removed.
Need to get 0 B/128 kB of archives.
After this operation, 8 192 B of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 271028 files and directories currently installed.)
Preparing to unpack .../libreadline7_7.0-3_i386.deb ...
Unpacking libreadline7:i386 (7.0-3) over (7.0-0ubuntu2) ...
dpkg: error processing archive /var/cache/apt/archives>/libreadline7_7.0-3_i386.deb (--unpack):
trying to overwrite shared '/usr/share/doc/libreadline7/changelog.Debian.gz', which is different from other instances of package libreadline7:i386
/var/cache/apt/archives/libreadline7_7.0-3_i386.deb
E: Sub-process /usr/bin/dpkg returned an error code (1)`
Results of dpkg -S readline.h :
octave-doc: /usr/share/doc/octave/octave.html/Customizing-readline.html
nodejs: /usr/share/doc/nodejs/api/readline.html
libreadline-dev:amd64, libreadline-dev:i386: /usr/include/readline/readline.h
Results of dpkg -l | grep readline :
ii libreadline-dev:amd64 7.0-3 amd64 GNU readline and history libraries, development files
iU libreadline-dev:i386 7.0-3 i386 GNU readline and history libraries, development files
iF libreadline7:amd64 7.0-3 amd64 GNU readline and history libraries, run-time libraries
iU libreadline7:i386 7.0-0ubuntu2 i386 GNU readline and history libraries, run-time libraries
ii readline-common 7.0-3 all GNU readline and history libraries, common files
Results of apt-cache policy libreadline7:i386 :
libreadline7:i386:
Installed: 7.0-0ubuntu2
Candidate: 7.0-3
Version table:
7.0-3 500
500 http://ua.archive.ubuntu.com/ubuntu bionic/main i386 Packages
*** 7.0-0ubuntu2 100
100 /var/lib/dpkg/status
I've used 18.04 since I updated from the previous version. Maybe that's why something incompatible with 18.04 was added.
Results of sudo apt-get remove libreadline7 -a=i386 :
E: Command line option 'a' [from -a=:i386] is not understood in combination with the other options`
Results of sudo apt-get remove libreadline7 : https://pastebin.com/AUmqPyT2
Results of sudo apt-get remove readline7:i386 :
Depends: libreadline7:i386 (= 7.0-3) but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution)
I also got another readline dependency error about. Should I post it here?
