After I installed 18.10 (when it was beta) and started to install all software I got this problem with MyPaint. Today this problem still persists. Universe repository is enabled. I was able to install it from flatpak thought.
sudo apt -f install doesn't see any problems.
When I'm trying to install MyPaint:
$ sudo apt install mypaint
Reading package lists... Done
Building dependency tree
 mypaint : Depends: mypaint-data (>= 1.2.0-4.1) but it is not going to be installed
$ apt-cache policy mypaint mypaint-data
mypaint:
  Installed: (none)
  Candidate: 1.2.0-4.1
  Version table:
     1.2.0-4.1 500
        500 http://archive.ubuntu.com/ubuntu cosmic/universe amd64 Packages
mypaint-data:
  Installed: (none)
  Version table:
     1.2.0-4.1 500
        500 http://archive.ubuntu.com/ubuntu cosmic/universe i386 Packages
R S
  • 2,649
sudo apt install mypaint-data
This command line resolves the problem but it removes Gimp (and installing Gimp after MyPaint will remove MyPaint).
R S
  • 2,649
Jeryosh
  • 747
I have the same problem on Ubuntu 18.04 and before on Fedora 26 and I didn't find any solution except swipe to another simple painting program like "Kolourpaint" you can install it from Ubuntu software (Gnome software center) or by executing the following command:
sudo apt install kolourpaint
Qudor Eng
  • 181
