Ubuntu 18.04 TLS has moved to CUDA 9.1 now, which deprecates the Nvidia Fermi Architecture.
I have tried installing the cuda 8 toolkit from nvidia with an --override option (to discard compiler verification) butthe installation failed as follows:
Command: sudo ./cuda_8.0.61_375.26_linux.run --override --toolkitpath /usr/local/cuda-8.0/
Output:
You are attempting to install on an unsupported configuration. Do you wish to continue?
(y)es/(n)o [ default is no ]: y
Install NVIDIA Accelerated Graphics Driver for Linux-x86_64 375.26?
(y)es/(n)o/(q)uit: n
Install the CUDA 8.0 Toolkit?
(y)es/(n)o/(q)uit: y
Enter Toolkit Location
 [ default is /usr/local/cuda-8.0 ]: /usr/local/cuda-8.0
Do you want to install a symbolic link at /usr/local/cuda?
Install the CUDA 8.0 Samples?
Enter CUDA Samples Location
 [ default is /home/user ]:
Installing the CUDA Toolkit in /usr/local/cuda-8.0 ...
Warning: cannot find Toolkit in /usr/local/cuda-8.0. Use --toolkitpath to specify the toolkit location.
Installing the CUDA Samples in /home/user ...
sh: 1: /usr/local/cuda-8.0/bin/cuda-install-samples-8.0.sh: not found
chown: cannot access '/home/user/NVIDIA_CUDA-8.0_Samples': No such file or directory
= Summary =
Driver:   Not Selected
Toolkit:  Installation Failed
Samples:  Installation Failed
