I upgraded my server from 16.04 Ubuntu to 18.04.
After running do-release-upgrade and rebooting apache2 was masked.
I used this Q&A to unmask it, but but one question remains: why was the service masked?
Tim
  • 33,500
guettli
  • 1,765
Between versions 16.04 and 18.04, apache2 differs. 16.04 has Apache 2.4.18-2 whereas 18.04 has Apache 2.4.29-1. After running do-release-upgrade, Apache will have been upgraded.
Potentially, between 2.4.18-2 and 2.4.29-1 a change could have been made to the configuration file syntax which would cause Apache to fail is unexpected ways, or be configured unsafely. Unfortunately, do-release-upgrade doesn't know wether or not this is the case, so it is forced to mask it either way.
For your own safety, the service is masked until you manually re-enable it. The idea is that you verify that your configuration files are still correct, and then you can unmask it.
Tim
  • 33,500
