malformed line 1 in source list /etc/apt/sources.list.d/home:stevenpusser.listn(type) E:The list of sources could not be read. Now I can't issue any sudo commands. This message is greek to me. I can't find /etc/apt/sources.list.d How can I fix this problem? I was trying to add the palemoon browser.
RobMit
  • 23
In terminal do:
ls /etc/apt/sources.list.d/*pusser*.list
and/or
grep -i pusser /etc/apt/sources.list.d/*.list
on any found filenames, do:
more /etc/apt/sources.list.d/found_filename_here.list
Edit that output into your question, and then send a comment to @heynnema, and I'll take a look for you.
Update #1:
I asked that you put the output of the above commands as an edit of your original question, as trying to read that data in comments is difficult.
But right now you should be able to do the following...
sudo rm -i /etc/apt/sources.list.d/home:stevenpusser.list
heynnema
  • 73,649
