I want to set the speaker and microphone volume to zero or mute them every time my laptop starts, even if the last time I shut down my computer they where not muted. Just like what Kali Linux does. Thanks in advanced.
Asked
Active
Viewed 226 times
This answer from stack exchange should do the trick: Set Ubuntu Sound Volume on boot
From the question you want to use this command:
`/usr/bin/amixer -c 0 sset Master,0 0% > /dev/null`
From the answer you want to add the command in:
/etc/rc.local
Insert the command after the first line and before the last line:
#!/bin/sh # <---- This is the first line
exit 0 # <---- This is the last line
In my Ubuntu 16.04 LTS sound is already muted on boot. This happens to others as well: How to make my microphone unmuted on startup?
Check the file /etc/modprobe.d/alsa-base.conf and look for the line:
options snd-hda-intel model=auto enable=yes
If it exists either delete it or put # in the first character position.
WinEunuuchs2Unix
- 105,762
