I am ultimately trying to replace xhci_hcd with ehci_hcd since I think it may be causing a start up problem. In order to do so, I need to be able to recompile the kernel apparently. So I tried looking at the wiki to figure out what to do.
After running sudo apt-get build-dep linux-image-$(uname -r), I tried executing the "Modifying the configuration" instructions editconfigs command, here was the output:
linux-signed-4.15.0
➜  linux-signed-4.15.0 sudo fakeroot debian/rules editconfigs
dh editconfigs
dh: Unknown sequence editconfigs (choose from: binary binary-arch binary-indep build build-arch build-indep clean install install-arch install-indep)
debian/rules:35: recipe for target 'editconfigs' failed
make: *** [editconfigs] Error 2
All the other commands seemed to work. Finally, I tried the advice here which suggested doing
apt-get source linux-source
which, as the OP says, gives an "undersirable" linux-meta folder. And sure enough it failed on edit-configs:
linux-meta-4.15.0.36.38
    ➜  linux-meta-4.15.0.36.38 sudo fakeroot debian/rules editconfigs
    make: *** No rule to make target 'editconfigs'.  Stop.
The OP suggests instead that this command put him "on the right track":
sudo apt install linux-source
giving a source file linux-source-4.15.0 in /usr/src/. However this fails on the clean and editconfig commands both:
clean
➜  linux-source-4.15.0 sudo fakeroot debian/rules clean
sed: can't read Makefile: No such file or directory
for i in debian.master/control.stub.in; do                                      \
  new=`echo $i | sed 's/\.in$//'`;                                      \
  cat $i | sed -e 's/PKGVER/4.15.0/g'                              \
        -e 's/ABINUM/36/g'                                       \
        -e 's/SRCPKGNAME/linux/g'                             \
        -e 's/=HUMAN=/64 bit x86/g'                                    \
  > $new;                                                               \
done
flavours="debian.master/control.d/vars.generic debian.master/control.d/vars.generic-lpae debian.master/control.d/vars.lowlatency debian.master/control.d/vars.snapdragon";\
for i in $flavours; do                                                  \
  /bin/bash -e debian/scripts/control-create $i "true" |        \
        >> debian.master/control.stub;                                          \
done
echo "# placebo control.stub for kernel-wedge flow change" >debian/control.stub
cp debian.master/control.stub debian/control
export KW_DEFCONFIG_DIR=debian.master/d-i && \
export KW_CONFIG_DIR=debian.master/d-i && \
LANG=C kernel-wedge gen-control 4.15.0-36 | \
        perl -f debian/scripts/misc/kernel-wedge-arch.pl amd64 \
        >>/usr/src/linux-source-4.15.0/debian/control
dh_testdir
dh_testroot
dh_clean
# d-i stuff
rm -rf debian.master/d-i-amd64
# Generated on the fly.
rm -f debian.master/d-i/firmware/amd64/kernel-image
# normal build junk
rm -rf debian.master/abi/4.15.0-36.39
rm -rf /usr/src/linux-source-4.15.0/debian/build
rm -f /usr/src/linux-source-4.15.0/debian/stamps/stamp-*
rm -rf debian.master/linux-*
# This gets rid of the d-i packages in control
cp -f debian.master/control.stub debian/control
cp debian.master/changelog debian/changelog
# Install the copyright information.
cp debian.master/copyright debian/copyright
# Install the retpoline extractor.
cp debian/scripts/retpoline-extract-one scripts/ubuntu-retpoline-extract-one
cp: cannot create regular file 'scripts/ubuntu-retpoline-extract-one': No such file or directory
debian/rules:110: recipe for target 'clean' failed
make: *** [clean] Error 1
editconfigs
➜  linux-source-4.15.0 sudo fakeroot debian/rules editconfigs
dh_testdir;
/bin/bash -e debian/scripts/misc/kernelconfig editconfigs
This does not appear to be the kernel source directory.
debian/rules.d/1-maintainer.mk:43: recipe for target 'editconfigs' failed
make: *** [editconfigs] Error 1
Here is my Ubuntu version:
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.1 LTS
Release:        18.04
Codename:       bionic
Any further ideas?
Dair
  • 181
I'm using 18.10 and encountered similar problems starting with sudo fakeroot debian/rules clean (ubuntu-retpoline-extract-one': No such file or directory).
What I had to do to get it working:
  • After running apt-get source linux-image-$(uname -r):
    cd /usr/src/linux-source
    bunzip2 linux-source-4.18.0.tar.bz2
    tar xf linux-source-4.18.0.tar
    mv linux-source-4.18.0/* . # if you don't do this you will get the "ubuntu-retpoline-extract-one no such file" error
    mkdir debian/stamps # otherwise build failure because touch command fails
  • Before building (fakeroot debian/rules binary-headers ...):
    apt install bison flex libelf-dev fakeroot build-essential crash kexec-tools makedumpfile kernel-wedge libncurses5 libncurses5-dev libelf-dev asciidoc binutils-dev libudev-dev pciutils-dev # some of these may have already been installed, and some may not even be needed.
After that, I could successfully run:
    sudo fakeroot debian/rules binary-headers binary-generic binary-perarch
Poo Bah
  • 101
FYI as of 20.10 the list of packages to have installed before building has changed. Note that pciutils-dev has been replaced with libpci-dev. Also the install demands libiberty-dev.
So one needs to do this:
sudo apt install bison flex libelf-dev fakeroot build-essential crash kexec-tools makedumpfile kernel-wedge libncurses5 libncurses5-dev libelf-dev asciidoc binutils-dev libudev-dev libpci-dev libiberty-dev
