Everybody, I am new to Ubuntu. And I try to install Ubuntu 18.04 under windows Linux subsystem.
In one step I am going to install libdvd-pkg, but get an error as shown below:
sudo apt-get install libdvd-pkg
[sudo] password for xyz:
Reading package lists... Done
Building dependency tree
libdvd-pkg is already the newest version (1.4.2-1-1).
libdvd-pkg set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
7 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up libdvd-pkg (1.4.2-1-1) ...
libdvd-pkg: Checking orig.tar integrity...
/usr/src/libdvd-pkg/libdvdcss_1.4.2.orig.tar.bz2: OK
libdvd-pkg: Unpacking and configuring...
libdvd-pkg: Building the package... (it may take a while)
libdvd-pkg: Build log will be saved to /usr/src/libdvd-pkg/libdvdcss2_1.4.2-1~local_amd64.build
failed to set securebits to 024/0x14
dpkg: error processing package libdvd-pkg (--configure):
installed libdvd-pkg package post-installation script subprocess returned error exit status 1
Setting up ruby-molinillo (0.6.4-1) ...
dpkg: unrecoverable fatal error, aborting:
unable to install updated status of 'ruby-molinillo': No such file or directory
E: Sub-process /usr/bin/dpkg returned an error code (2)
Is there anybody, who can explain this?
