15
How do you disable the screensaver/powersave function in Ubuntu 18.04?
In Ubuntu 16, you disabled the screensaver in two steps:
  1. First, opening the screensaver gui and selecting "none". But this alone didn't stop the monitor from blanking.
  2. The X server had its own powersave feature that would turn off monitor output when nothing on the screen changed. To disable that, you had to run xset s off.
In Xubuntu 18.04, the second part no longer works. Even though I've run xset s off, my monitor output still blanks if nothing changes after a few minutes. How do I fix that?
I'm running the XFCE desktop, with the xubuntu-desktop package, if that matters.
Cerin
  • 6,923
Since you're running Xfce, you could try changing the settings of the Xfce Power Manager.
Find Power Manager in the Applications menu or run xfce4-power-manager -c from the terminal. Then you can change the settings in the Display tab.
If Display Power Management is turned ON, then the Power Manager should be in control instead of X11. You should then be able to prevent blank/sleep/power off by setting the appropriate sliders to Never.
wjandrea
  • 14,504
Cinnam
  • 211
Try xset s off -dpms.
Source: https://bbs.archlinux.org/viewtopic.php?id=122825
brettv
  • 129
