13
After I updated to Ubuntu 18.10 my sound device isn't recognized anymore. Only a dummy device is shown.
I have an onboard Intel device:
lspci -nnk | grep -A2 Audio
00:1b.0 Audio device [0403]: Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller [8086:1e20] (rev 04)
    Subsystem: Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller [8086:2036]
    Kernel driver in use: snd_hda_intel
    Kernel modules: snd_hda_intel
The command pacmd list-cards does not show any devices:
:~$ pacmd list-cards
0 card(s) available.
This message in /var/log/syslog might have to do something with the problem:
Oct 19 21:02:06 MyComputerName pulseaudio[14331]: E: [pulseaudio]
backend-ofono.c: Failed to register as a handsfree audio agent with
ofono: org.freedesktop.DBus.Error.ServiceUnknown: The name org.ofono
was not provided by any .service files
Does anybody have the same issue? How can I fix this?
user5950
  • 6,406
5 Answers5
18
Try
sudo apt purge timidity-daemon
and
reboot
abu_bua
  • 11,313
I turned out that the cause where old pulseaudio config files. I did remove them with:
sudo apt purge alsa-base pulseaudio
This will cause some dependencies to be purged as well. So the easiest way to reinstall everything is to do:
sudo apt install ubuntu-gnome-desktop
But this might bring you some packages back, you had intentionally removed before. So keep track of what is being installed.
Another way to reinstall what was removed is to simply copy the list of uninstalled packages from the terminal:
The following packages will be REMOVED:
   alsa-base* indicator-sound* libcanberra-pulse* paprefs* pulseaudio*
   pulseaudio-equalizer* pulseaudio-esound-compat* pulseaudio-module-bluetooth*
   pulseaudio-module-gsettings* pulseaudio-module-raop*
   pulseaudio-module-zeroconf* ubuntu-desktop* ubuntu-gnome-desktop*
So for me this was:
sudo apt install alsa-base indicator-sound libcanberra-pulse paprefs\
pulseaudio pulseaudio-equalizer pulseaudio-esound-compat\
pulseaudio-module-bluetooth pulseaudio-module-gsettings\
pulseaudio-module-raop pulseaudio-module-zeroconf ubuntu-desktop\
After you have reinstalled everything you shout do:
sudo alsa force-reload
After this the sound device should work again.
user5950
  • 6,406
this is what I did that got my 18.04 to recognize audio again:
sudo apt install --reinstall alsa-base pulseaudio
your mileage may vary. but it worked for me. (tm)
stu
  • 173
Install pavucontrol using
sudo apt-get install pavucontrol
After the installation, open it by typing the command pavcontrol in terminal and select the output devices.
Kulfy
  • 18,154
I just had a similar but slightly different experience after upgrading from 19.04 to 19.10. Everything was fine until I plugged my laptop into a DisplayLink hub then I lost all sound. I saw on another forum people talking about losing sound after plugging into an HDMI screen so this is similar.
What I had was that all my devices showed up but I couldn't get any sound out of them. In the sound control panel I could choose a USB headset but when I click on test, there are no speakers to click on to perform the test. The simple fix for me was just to kill and restart pulseaudio
pulseaudio --k
pulseaudio --start
After that everything came back to life.
Wayno
  • 189
