We are planning for Ubuntu OS upgrade next year, wanted to know which version of Postgres is supported by default.
Asked
Active
Viewed 5,884 times
The default version of postgresql-10 in Ubuntu 18.04 and 18.10 is version 10.5. The default version of postgresql-11 is version 11.2 in Ubuntu 19.04 and version 11.5 in Ubuntu 19.10. postgresql-common is a dependency of postgresql-10. The default version of postgresql-12 is version 12.2 in Ubuntu 20.04
Results of dpkg --list | grep -i postgres
ii libpq5:amd64 10.5-0ubuntu0.18.04 amd64 PostgreSQL C client library
ii postgresql-10 10.5-0ubuntu0.18.04 amd64 object-relational SQL database, version 10 server
ii postgresql-client-10 10.5-0ubuntu0.18.04 amd64 front-end programs for PostgreSQL 10
ii postgresql-client-common 190 all manager for multiple PostgreSQL client versions
ii postgresql-common 190 all PostgreSQL database-cluster manager
karel
- 122,292
- 133
- 301
- 332
I use Postgres on a Ubuntu 18.04 server for map generation. My undertanding is that Ubuntu server does not come with Postgres installed by default and that you can choose to install whichever version suits your needs with the following:
sudo apt-get install postgresql-xx
where xx is the version. I used version 10, so that would be:
sudo apt-get install postgresql-10
